Author Topic: 452 Heads  (Read 3870 times)
Re: 452 Heads
« Reply #30 on: September 07, 2009 - 09:12:55 PM »
I got some indy steel heads :bigsmile:
Offline 71chally416
    • The Streetwalker
Re: 452 Heads
« Reply #31 on: September 07, 2009 - 09:28:28 PM »
My old RR. Had ported Iron 915's on a single 4 bbl 440 in a 3300lb body.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: 452 Heads
« Reply #32 on: September 07, 2009 - 09:42:09 PM »
I dont think my little 440 will handle them!
Don
Member Since January 14, 2002
moparniac
Re: 452 Heads
« Reply #33 on: September 08, 2009 - 08:11:32 AM »
http://www.youtube.com/watch?v=ghVPBY6wrZ8
Nice leave but I dont think don is looking for big compression and race gas etc....... was that all motor BTW?  :working:
Offline moper
Re: 452 Heads
« Reply #34 on: September 08, 2009 - 12:10:23 PM »
A lot depends on the heads to begin with. The last set of 452s I did I had more than 16 hours in. They flowed in the high 280s and 210 on the exh with 2.14 intakes and 1.81 exh. However, in order to get the seats ad guides in shape, plus trim downt eh guides for positive seals and cut the spring seats for dual springs, plus the milling to get the cc's reasonable and the milling to make the intake fit right after the deck milling... I could have had a set of out of the box RPMs. So, if you look at benefit vs cost, there is only a slight nod if any towards aluminum. If it was me, I would concentrate less on 2.18/1.88 valves and focus on new guides and smaller valves, and a shop that can cut the seats with modern equipment.  A propoerly sized guide and new valve will make more power than a bigger valve and stone valve job or loose guides. Especially in the lift ranges you are talking. You can grind all day, or have the throat work done as part of a performance valve job. In any event, I think $900 including parts will not be able to get it done very well. And in regard to porting, Less is MORE.
  • Pearl Harbor, HI
    • C-C.com
Re: 452 Heads
« Reply #35 on: September 08, 2009 - 10:28:46 PM »
Thank you for the input.  I will take it under advisement.
Don
Offline 71chally416
    • The Streetwalker
Re: 452 Heads
« Reply #36 on: September 08, 2009 - 10:45:05 PM »
Yeah, that was in my pre-Nitrous days  :lol: Rebuilt stock rods, crank and heavy Sealed Power pistons with a decked block. It was the old motor from my '70 Challenger (a rebuilt '67 440 from a GTX) Lots of head porting, a big Crane solid cam and a Weiand Intake with lots of welding and porting too with an 850 DP carb and MSD 7AL ignition.  Also had a monsterously heavy Dana with 41 spline axels and 10 lugs on each wheel from my 4 speed days and an old school ladder bar suspension.
  • Pearl Harbor, HI
    • C-C.com
Re: 452 Heads
« Reply #37 on: September 08, 2009 - 11:01:19 PM »
Gee is that all!  It sure sounds awesome!
Don
