Author Topic: Removing stuck on 3m swirl remover  (Read 1011 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: September 02, 2009 - 09:15:06 PM »
Hello! I rubbed my paint out with 3m swirl remover, but like a dummy I didn't mask anything off. There are spots in the door jams and on the firewall and inner fenders. Soap and water do not seem to get them off. Is there anything I can use to remove the dried up spots of swirl remover?
Thanks!
Offline 72cudamaan
Re: Removing stuck on 3m swirl remover
« Reply #1 on: September 02, 2009 - 09:32:03 PM »
Try using fresh swirl remover on a rag. Just might soften up the old stuff. Depending on how fresh the paint is and what type of paint you could also use laquer thinner.Though that isnt my first choice.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline FJ5_440
  • Wisconsin
« Reply #2 on: September 02, 2009 - 09:36:42 PM »
Stay away from laquer thinner, it is a pretty harsh solvent for something like that.  I might try wd 40 or maybe wax and grease remover.
** Shane **
Offline 73Barracuda340
« Reply #3 on: September 02, 2009 - 10:22:13 PM »
I use either more swirl remover on a rag as mentioned above, or a little bit of fine rubbing compound or clearcoat cleaner on a rag.
Offline elitecustombody
  • Supra collector
« Reply #4 on: September 02, 2009 - 11:56:11 PM »
compound or wax & grease remover
Stefan B
Offline rallye73
  • Model cars for the big boys!!
« Reply #5 on: September 03, 2009 - 12:01:22 AM »
Try quick detailer. I've used it for years to remove compound when buffing cars.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
« Reply #6 on: September 03, 2009 - 05:07:04 PM »
Cool! Thanks for the advice!
Offline Skeletoil
« Reply #7 on: December 12, 2009 - 11:34:14 PM »
If all else fails use a very fine clay bar. Don't get heavy with it. The fine will take awhile but is safe even on new finishes. Go easy.
Offline babyelephant
  • Ol' Kozmic Blues again Mama
    • WPC Club of Norway
« Reply #8 on: December 13, 2009 - 07:49:02 AM »
I'd give it a try doing an IPA (don't remember now what the letters are short for...) that means a mix of isopropanol and destilled water. This will remove all oil deposits from the rubbing compound (hardly visible) AND the spots you want to get rid of. It's recommended to to this to your complete paintjob after polishing step and before you add a layer of wax. This prepares your paint job for waxing, giving a better and long-lasting result. As I think you've already waxed your car, you could do the IPA now  only where you find it necessary by light rubbing the IPA with a moist microfibre towel, and dry it off with a clean mf towel.
I learned the same way as you, earlier this year. I masked everything, I thought, but it was obvious that I'd used too much rubbing compund or maybe revved the polisher too early/high.
JH23J0B
88 BMW 635 CSiA
87 Trans Am GTA
x RH23G8E
