Author Topic: engine an trannny install  (Read 642 times)
Offline kmyles
« on: September 03, 2009 - 10:44:35 AM »
Went to install my engine and tranny last night but it didn't work out so well. :bricks1: Couldn't get it tilted enought to get in so back at it again tonight :pullinghair:! One question, should tranny fluid be coming out the tail end as I tilt it???  :clueless:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Re: engine an trannny install
« Reply #1 on: September 03, 2009 - 11:47:19 AM »
The rear trans seal only works when the driveshaft is installed.  Fluid will run out the tailshaft of you don't use a plug.
By the way...this is the easiest way to install an engine/trans in a Mopar.
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: September 03, 2009 - 11:59:11 AM »
If you don't have a tailshaft plug, you can use a baggie over the end with a tight rubber band holding it on.     :2thumbs:
Ken  --  In Georgia
Offline kmyles
« Reply #3 on: September 03, 2009 - 01:42:04 PM »
Nicely done :2thumbs: Thanks for the info!!
Thanks Oldschool, I'll give that a try tonight!! :2thumbs:
_________
Kevin
