Hey Moper, just wondering, you say that the Lunati co. suggests running dual springs with their cams, right? I looked up the suggested spring for the above referenced cam, but the spring is only a single spring, with damper, and is a 1.500" outside diameter. I copied the info from the site, here's what it says:
Brand Lunati
Manufacturer's Part Number 73815
Part Type Valve Springs
Product Line Lunati Intro Series Valve Springs
Summit Racing Part Number LUN-73815
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.500 in.
Coil Bind Height (in) 1.130 in.
Damper Spring Included Yes
Spring Rate (lbs/in) 342 lbs./in.
Inside Diameter of Outer Spring (in) 1.086 in.
Valve Spring Style Standard
Coated No
Quantity Sold as a set of 16.
Here's the link to these suggested springs:
http://www.summitracing.com/parts/LUN-73815/I'm just wondering what's going on, if Lunati wants a dual spring to be used, then why is a single being suggested? Did someone mess up some where? I hope not, don't want to mess something up because of someone else's mistake...
