Author Topic: Clearance Between Cam Sprocket & Cam Plate?  (Read 570 times)
Offline cwestra
« on: September 04, 2009 - 05:11:34 PM »
Anyone know how much clearance there should be between the rear cam sprocket surface and the front of the cam plate on a small block?  I just mounted mine and after tightening the cam bolt with eccentric and washer on, I bet I have less than .004".  Seems like a tight fit but rotates fine.  I don't know what it should be.
Corey - in Northern Indiana
Offline 72cudamaan
Re: Clearance Between Cam Sprocket & Cam Plate?
« Reply #1 on: September 04, 2009 - 06:33:39 PM »
As long as there is clearance you'll be just fine. You really dont want much clearance anyway. Otherwise the cam could "walk" front to back.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline cwestra
« Reply #2 on: September 05, 2009 - 06:16:26 AM »
Sounds good.  Thanks.
