Author Topic: charcoal canister  (Read 1932 times)
Offline 30below
charcoal canister
« on: September 04, 2009 - 05:47:43 PM »
Anyone have a pic of how the bracket mounts to the rad cradle?
Offline quapman
    • Auto-Grip on Facebook
Re: charcoal canister
« Reply #1 on: September 04, 2009 - 06:00:24 PM »
No pic right now, but it mounts to the pass. inner fender, next to the washer bottle. There should be three holes (or dimples in a new inner fender) in a triangle pattern.
Offline AZDAN
« Reply #2 on: September 06, 2009 - 09:52:08 PM »
hope this helps
« Last Edit: September 06, 2009 - 09:57:06 PM by AZDAN »
Offline AZDAN
« Reply #3 on: September 06, 2009 - 09:59:21 PM »
one more
Offline lemming303
  • San Antonio, TX
« Reply #4 on: September 06, 2009 - 10:28:25 PM »
Can yall please explain what that is and what it does? Thanks.
Kevin
73 Challenger Rallye - first project
Offline quapman
« Reply #5 on: September 07, 2009 - 07:12:32 AM »
That's high-tech 70's emission control.
In theory, the vapors from the gas tank (metal line attached to inner fender)and float bowl collect in the cannister, then go back to the carb (big line at the base) to combine with the other fuel and get combusted (burned).
A vented gas cap has something to do with how it all works also.
Most of these got tossed back in the 80's as another "that thing doesn't work" part of these cars.
Offline burdar
« Reply #6 on: September 07, 2009 - 08:28:17 AM »
I thought that only 1970 Challengers without the California emissions equipment came with a vented cap.  I thought the whole point was to keep the vapors in the tank and NOT let them out into the atmosphere.
Shouldn't they all come with a sealed cap?
« Reply #7 on: September 07, 2009 - 03:27:44 PM »
 The canister bracket actuall mounts onto the inner fender & it is just a tank that captures fuel vapors from the tank & carb ,then when the car was started it draws in air throught the canister & burns off the trapped vapors , what is rediculous is how much vapor is released into the atmosphere everytime the fuel tank is filled replacing vapor with liquid , even on todays vehicles where they have sealed systems & pressurized testing done to be sure the system is sealed far more vapor is released into the atmosphere just filling the tank every time itme than the vapor capture would have any effect on .... the insanity continues LOL
Offline shadango
« Reply #8 on: September 07, 2009 - 04:36:29 PM »
LOL
Not to mention how much energy and material, and therefore all the bad byproducts of the process, had to go into making the parts to recover the fuel fumes....  :violin:
I bought this new fangled gas can and it claims to reduce vapors to the atmosphere...In the meantime the design is SO difficult to use in practice....not to mention that when the can is emptying, the vapor part leaks likea sieve all over the ground....
what a joke.
Offline burdar
« Reply #9 on: September 07, 2009 - 04:44:08 PM »
A lot of states require gas stations to use fuel pumps that recover the vapors.
Offline ashley_j
« Reply #10 on: September 07, 2009 - 04:54:55 PM »
I noticed that the vapor line from the tank in the pic ran up to the windshield washer tank. Is the that standard for all years?  :clueless:
Mine stopped at the firewall area on my '73.
Jeff
 :wavingflag:
2009 Dodge Charger 3.5 (Son's Ride)
2008 PT Cruiser Turbo (Mom's Hotrod)
2006 Grand Caravan SXT (you'd be surprised)
1973 Dodge Challenger (383ci w/425HP)
NEVER FORGET!!!!!!!!!!!!
Offline quapman
« Reply #11 on: September 07, 2009 - 06:04:16 PM »
My 73 is identical to the one in the pics. Sounds like yours got cut short back in the day.
Offline ashley_j
« Reply #12 on: September 07, 2009 - 06:08:59 PM »
I thought as much but someone took the time to flair the end after cutting.  :dunno:
That was what confused me about the line. Thanks for the info!!! :thumbsup:
Jeff
 :wavingflag:
« Reply #13 on: September 07, 2009 - 06:10:22 PM »
Jeff
 :wavingflag:
My '73 has a two part line... about the firewall there is a 1" section of rubber hose connected to the under hood metal line that runs forward & up by the washer reservoir.
Offline ashley_j
« Reply #14 on: September 07, 2009 - 06:47:56 PM »
That's interesting!! I may need to start looking for a seperate piece instead of a single line. Thanks.     :-\
Jeff
:wavingflag:
