I have an AVS on my big block work truck. At my elevation, about 4800 ft the tuning book that came with the carb was useless, even after adjusting for altitude. Ended up buying the Edel O2 sensor kit ( a little over $100), and was able to tune every circuit in the carb.
Found out the transfer slots were running lean (between idle and main metering), so I hand filed the slots 10% wider and this fixed the slight lean hesitation off-idle prior to main metering circuit. As I have read, driving around town you spend alot of time on the transfer circuit, not the main metering circuit.
Engine runs very well, and I have no complaints. There's a guy at a local parts yard that does NOT like edy carbs, but he had to admit my engine ran smooth and strong.
I'm going to use the O2 sensor to tune the TQ carb I'm putting on my challenger.
hope this helps.
