Author Topic: Rattle  (Read 812 times)
Offline BadJoey
Rattle
« on: September 05, 2009 - 09:17:13 PM »
I'm getting a rattle from the bell housing area . It happens right at 3500 RPM's every time . It stops if I push the clutch in . Everything is new . I haven't dropped the bell cover to look for the problem yet , hopefully Monday . I wonder if it is the trow out bearing (not a bad bearing , rattle) ? I tried picking up the peddle with my foot but the noise did not change . All I can think of is the bearing vibrating against the pressure plate arms , but then why wouldn't it stop when I picked up on the peddle . Any ideas are more then welcome . Clutch is not slipping and I do not think it is major . :working:
Re: Rattle
« Reply #1 on: September 06, 2009 - 01:36:35 AM »
do you have a spring on the release lever to a load on it , it hooks the lever & the corner of the belhousing
Re: Rattle
« Reply #2 on: September 06, 2009 - 06:01:25 AM »
Do you have a bushing or pilot bearing installed in the back of ther crank for the input shaft in the trans?  Is your trans gear oil level low?
Offline BadJoey
Re: Rattle
« Reply #3 on: September 06, 2009 - 08:14:49 AM »
I can not remember putting a spring in . I do remember checking for the pilot bearing (tore up a clutch like that as a kid) oil is full as well . I am on the way out now (other things on the list for today) but i will be under the car tomorrow for sure . Thanks guys . :bigshades:
Re: Rattle
« Reply #4 on: September 06, 2009 - 08:35:34 AM »
There is a notch in the fork where the spring should be.
Offline BadJoey
Re: Rattle
« Reply #5 on: September 06, 2009 - 11:48:31 PM »
Is this spring inside or outside of the bell housing ?  :bigshades:
Re: Rattle
« Reply #6 on: September 07, 2009 - 12:31:31 AM »
outside , connects inth ethe slot in the fork & the hole in the bottom corner of the belhousing
Offline BadJoey
Re: Rattle
« Reply #7 on: September 07, 2009 - 09:22:27 AM »
I know I do not have a spring there and that is probably my noise . When I got the car everything came in boxes so I had to feel my way through things . Thank goodness and cc.com . You guys are the best . THANKS !!!  :clapping: :clapping:
