Author Topic: Axle Shaft End Play / I don't get it........  (Read 1746 times)
Offline Glennster
« on: September 06, 2009 - 05:23:39 PM »
I've scratched my head raw and I hate to say it, but I can't figure out how or where to adjust for end play. I feel like an idiot asking, but I can't figure it out. The instructions I have don't give me a real clear picture of the '' ADJUSTER '' or the '' LOCK ''.
 Can you guys post a few pictures to help the challenged guy to get it?
THANKS!!!!!
Re: Axle Shaft End Play / I don't get it........
« Reply #1 on: September 06, 2009 - 06:03:03 PM »
Ck out Shelbydogg's How To ...... or do you have the Green Bearing setup?
http://www.cuda-challenger.com/cc/index.php?topic=35471.0
Offline Glennster
« Reply #2 on: September 07, 2009 - 12:27:32 AM »
I do not have the Green bearings....
« Reply #3 on: September 07, 2009 - 12:33:42 AM »
on the right side you will see some tabs kind of like a crown sticking up behind the axle flange at the center of the plate that retains the axle , on one of the bolts there is a tab that hooks over into the crown , remove the bolt that the lock tab is held by & the crown will rotate , you may have to tap it with a punch to rotate it
Offline ashley_j
« Reply #4 on: September 07, 2009 - 03:44:23 AM »
I have a pic of a sample locking pawl.  :picture:
Jeff
 :wavingflag:
2009 Dodge Charger 3.5 (Son's Ride)
2008 PT Cruiser Turbo (Mom's Hotrod)
2006 Grand Caravan SXT (you'd be surprised)
1973 Dodge Challenger (383ci w/425HP)
NEVER FORGET!!!!!!!!!!!!
« Reply #5 on: September 07, 2009 - 08:39:17 AM »
I have my axle out waiting for an axle seal (I think it's being shipped by dog sled) so I thought I'd take a pic for you. The adjuster is the part between the flange and the bearing that looks like a huge crown nut.
Offline Glennster
« Reply #6 on: September 07, 2009 - 10:07:41 AM »
ashley_j / Jeff,
  There's the missing link!
I've got 2, 8 3/4 rear ends and NEITHER of them had the locker that you showed in the picture. Now I understand!
All I have to do now is find the lock!!!
THANK YOU ALL!!!
Offline quagmire
  • Traction Impaired......
« Reply #7 on: September 07, 2009 - 10:34:21 AM »
Luckily, that locking pawl is still readily available at a lot of vendors pretty cheap.  The adjuster isn't.  I'm pretty sure Mancini sells that, but so do a dozen other Mopar vendors.
Offline ashley_j
« Reply #8 on: September 07, 2009 - 04:41:25 PM »
Offline Changin Gears
« Reply #9 on: September 07, 2009 - 06:30:05 PM »
If you need it quick, or your cheap like me, they are pretty easy to fabricate.
