Author Topic: New Lifters (Soak in Oil First?)  (Read 1810 times)
Offline cwestra
« on: September 07, 2009 - 01:43:08 PM »
Getting ready to finish assembling my 340.  I have a new cam & lifters.  Do I need to soak them in oil before I install them or not?
Corey - in Northern Indiana
Re: New Lifters (Soak in Oil First?)
« Reply #1 on: September 07, 2009 - 02:13:17 PM »
the only lifters I have ever soaked are the Roller lifters where it is important to get oil into the roller before firing the engine up
Offline cwestra
« Reply #2 on: September 07, 2009 - 03:03:20 PM »
You're a wealth of knowledge, CP.  Thanks, again.
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #3 on: September 07, 2009 - 03:07:16 PM »
Remember to use break in cam lube.
Offline cwestra
« Reply #4 on: September 07, 2009 - 03:55:03 PM »
You bet.  Thanks.
Offline 71chally416
    • The Streetwalker
« Reply #5 on: September 07, 2009 - 04:09:23 PM »
I always like to soak hydraulic lifters in oil overnight so they injest some oil internally and the valvetrain doesn't clatter for 5 minutes on start up. Done that with every cam I've ever installed without a problem. Some like to just let the oil pressure pump them up and run them dry on startup. That's cool as long as a pushrod doesn't jump off a rocker arm because the lifter is totally collapsed, which will bend a pushrod.  :dunno:
Offline UKcuda
  • Tell them I'm on my way
« Reply #6 on: September 07, 2009 - 06:40:12 PM »
It's probably not necessary but when I change internal components I like to prime the oil system before start up so I know everything is at least half way oiled to where it should be before I fire it.
If you've got a long enough screwdriver with a hex on the top end you can shove it down the distributor hole and engage the pump and turn it with a drill until the pressure comes up on the guage (if you have a guage).  You can get a proper tool for it but I have a screwdriver that works OK.
To be really sure turn the engine 180 degrees and do it again.
As I say, probably not necessary but after I wiped out the mains on my brother's '67 AMC I always do it now just to be sure.
'72 'cuda
Offline cwestra
« Reply #7 on: September 09, 2009 - 12:51:05 PM »
I did end up soaking the lifters.  All but 3 of them filled.  The 3 that didn't, were not even close to being filled.  Even after pumping submerdged they still felt empty.  Will these pump up okay or do I have a problem?
« Reply #8 on: September 09, 2009 - 05:05:51 PM »
with 70 PSI pushed into them they will pump up
Offline cwestra
« Reply #9 on: September 09, 2009 - 06:08:10 PM »
Ok.  Just making sure.  Seemed a bit odd.
Offline Aussie Challenger
« Reply #10 on: September 10, 2009 - 06:27:39 AM »
  I always soak & prime hydraulic lifters before installing in a motor, however the earlier S.B. MOPARS can jack the valves open with disastrous results due to the oil not going up the push rods to lube the rocker gear.   :bigsmile:
  Priming the oil system before starting is a must.   :2thumbs:
« Reply #11 on: September 10, 2009 - 10:49:04 AM »
I always lube the shafts with break in lube as I assemble the engine but the only Mopars I know of that lube up the pushrods are the later Magnuns
