Author Topic: geting it started  (Read 958 times)
Offline HAWS
geting it started
« on: September 07, 2009 - 07:57:33 PM »
Hi, I'm new to this web site. I have a 70 cuda 340 six pack. I just got the car, and I'm having trouble starting it.  What I mean is, seems like I always flood it . Is there a trick to starting those six pack engines? Any advice would help thanks...Harry
Re: geting it started
« Reply #1 on: September 07, 2009 - 08:02:44 PM »
Is the choke stuck closed?  Shouldnt be a problem if gas isnt leaking past the floats or the choke stuck. Be careful of a backfire, but have you tried holding the throttle to the floor to clean it out?
Offline 73Chally
« Reply #2 on: September 07, 2009 - 08:06:50 PM »
Have you checked for spark from the coil?
wagesofsin
« Reply #3 on: September 07, 2009 - 08:26:27 PM »
be aware , the outboard carbs do not have anything to do with initial startup, they are vacuum operated, and only play into w.o.t.
make sure you are not stuck open on the outboards.
just a toss of my  :2cents:
« Reply #4 on: September 07, 2009 - 08:59:40 PM »
Is it an AAR? Either way, a nice car to start out with.  :wow:
« Reply #5 on: September 07, 2009 - 09:13:32 PM »
there are a lot of possibilities here
start with checking the float levels ,
 make sure the choke is only closing lightly or not even all the way .
 is it boiling the fuel when you shut it down , possibly you need to block the heat crossover port in the intake
 just push the pedal 1/2 way down before you start it cold to set the choke
 & yes the outboards do play a roll , they have mixture screws in the base plate also
