Author Topic: idle speed  (Read 491 times)
Offline HAWS
idle speed
« on: September 07, 2009 - 11:48:36 PM »
Ok I will admit I know nothing about a six pack setup.  When I advance my distributer, the idle goes up, but my idle adjustment screw on the center carb is all the way out so I can't lower the idle speed?? Ideas? Thanks :clueless: :clueless: :clueless: :clueless: You won't know unless you ask....
Offline Matt
  • 340 now a 416 stroker
  • 340 stroker 4spd "ya baby"
    • Car store automotive
Re: idle speed
« Reply #1 on: September 08, 2009 - 12:08:49 AM »
what is it revving at...may been it is got a vacumn leak somewhere.and sucking air..there should be some kind of way to lower it with out turning it all the way out.....Matt
Re: idle speed
« Reply #2 on: September 08, 2009 - 12:45:03 AM »
adjust the linkage to the outboard carbs , one of them is hoilding the throttle open
Offline HAWS
Re: idle speed
« Reply #3 on: September 08, 2009 - 11:46:39 AM »
thanks I will try that, what do you think I should set the total advance at?
Offline moper
Re: idle speed
« Reply #4 on: September 08, 2009 - 12:12:19 PM »
Like CP said.. idle speed should be set with the outboards disconnected, and after it's set then they should be adjusted for length and slid into the holes with no effort. Depending on the build, the idle should be between 650 and 900. I dont like anything over 800 myself but sometimes you have to.
