Author Topic: Dash Bezel  (Read 695 times)
Offline basement
Dash Bezel
« on: September 08, 2009 - 09:04:53 AM »
Having an issue with my windshield wipers and want to check the switch which is located in the upper left hand corner of the dash. It looks like the dash assembly is in three pieces. Oh, this is a '74' with a tic-toc-tach. What the easiest way to get to that wiper switch?
Re: Dash Bezel
« Reply #1 on: September 08, 2009 - 10:49:42 AM »
4 screws secure the panel just gently remove the panel after the 4 screws are out
Offline UKcuda
  • Tell them I'm on my way
Re: Dash Bezel
« Reply #2 on: September 08, 2009 - 10:58:43 AM »
When checking the switch removed from the dash I think you'll find it has to be earthed in order to work properly - I got a bit confused with mine before I realised that.
'72 'cuda
