I'm running a real similar set-up. 360, same compression, heads and intake. If yours is a Voodoo cam, same stick. I've got a 750 Holley. Not sure where my base timing is, mech advance is 38* at 3000...probably pretty close to 10* at idle.
I'm 12" at idle running PVC and 3 nipple breather, no power brakes. When everything was blocked off, I was 14".
Have you played with your idle bleed screws? That cam shouldn't be that bad, unless you're running a 318.
