Author Topic: Is my tranny a goner  (Read 765 times)
Offline dodge freak 2
« on: September 10, 2009 - 08:41:07 PM »
Well all summer my little 904 trans with a manual valve body was slow to engage and after 1 min would not move from a dead stop in any gear until about 2000 rpms. However after 3 to 5 mins trans would work great all day long. I did change the oil and filter when the problem forst started with no change.
Well now for the last few weeks it would slip in reverse when only when hot, believe that is a low band adjustment but I never pulled the pan off.
Today thou it slip in 3 gear at WOT, back off and tried again, would not hold. Can drive part throttle fine in 3 rd gear, just can not hold full power.
I think its DOA, no band adjustments or valve body work will repair it, needs a full overhaul / right  ???
Offline tactransman
Re: Is my tranny a goner
« Reply #1 on: September 10, 2009 - 08:44:41 PM »
yup!  :grinyes:
Terry-tactransman
Union, Mo.
« Reply #2 on: September 10, 2009 - 10:38:30 PM »
318 block, 360 MP "308" heads with 2.02 intakes, a custom 224 @ .050 cam, headers...dual quads, lol and daily 6500 rpms shifts. Car weight about 3700 lbs and 3.91 gears in back.
Rebuild the 904 (with 5 plate clutches and manual valve body) or move up to the 727 trans? (which means shorten the drive shaft and other minor mods)
« Last Edit: September 10, 2009 - 10:40:12 PM by dodge freak 2 »
Offline 426HEMI
« Reply #3 on: September 10, 2009 - 10:45:38 PM »
I would move up to the 727,   :2cents:  they are a lot stronger
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline tactransman
« Reply #4 on: September 11, 2009 - 06:34:20 AM »
If I have a choice to rebuild a 904 or a 727 I always pick a 727. They cost the same to rebuild and you have alot stronger trans.
Terry-tactransman
Union, Mo.
« Reply #5 on: September 11, 2009 - 09:59:03 AM »
Guess the 904 is staying in cause my old tranny shop were the brother took over said cause I had it done before and other cars there, it be $600 max to redo it "right" maybe $500 depending on how far its gone.
Cash is tight and last time did last 5 years I believe.
But if money wasn't an issue...well I would supercharge that motor too then, he he.
