Author Topic: What fits under the flat hood?  (Read 812 times)
Offline Glennster
« on: September 11, 2009 - 02:40:17 PM »
 I'm going to a 340 with an Air Gap ED Intake with a ED 800CFM Carb. Will that fit under a flat hood like my little Granny Challenger has on it?
Re: What fits under the flat hood?
« Reply #1 on: September 11, 2009 - 02:44:51 PM »
That's a good question.  I know that if you ordered a 340 from the factory, you automatically got the Rallye hood but I wouldn't think that was because of a clearence issue.  I mean they put 383 2-barrels in Cudas and Challengers with flat hoods.  The only thing I would measure is how much taller the "air gap" manifold is than the stock one.
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: September 11, 2009 - 03:28:54 PM »
the manifold height info is available on the edelbrock site. If you use a drop base air cleaner it might fit.
« Reply #3 on: September 11, 2009 - 03:45:50 PM »
Don't know if this will help, but my car used to have a 318 with a Edelbrock performer intake with a holly 600cfm under a flat hood.
Offline vinb
« Reply #4 on: September 11, 2009 - 04:08:42 PM »
Stock 4bbl intake is 4 1/2" at center of plenum and my Weiand #8007 is 5 1/2".
The Air Gap is approx. 5 1/2" according to there info...
I use a 1 1/2" drop base with a 2 3/4" tall element and a 3/4" carb spacer, Thermo-Quad carb and still have about 3/4" hood clearance on my Cuda...
Hope this info helps......
« Reply #5 on: September 11, 2009 - 04:32:53 PM »
Wow...then you could really run a nice fat aircleaner then if there was no carb spacer.
I have a 4" tall filter on my Dakota with a 400BB under the stock hood.  It looks sweet under there.
