Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
1971 challenger gas tank
« previous
next »
Print
Pages: [
1
Author
Topic: 1971 challenger gas tank (Read 2144 times)
mopar440
Jr. Member
on:
September 13, 2009 - 06:54:18 AM »
Hey guys not sure where to post this, when i fill up my car seems like it whooshes out a lot more air when i take the cap off then it used to, is this normal ,or should ther be no pressure at all ? do i need to do something with those goofy hose set ups in the back. put a new gas cap on, same thing !
Logged
wagesofsin
Guest
Re: 1971 challenger gas tank
Reply #1 on:
September 13, 2009 - 07:52:29 AM »
i thought the early tanks didnt have the hoses like the later ones to the vapor seperator.
regardless, it must not be venting.
make sure all the hoses are unobstructed.
Logged
Moparal
Permanent Resident
Reply #2 on:
September 13, 2009 - 09:26:39 AM »
my 70 has those ecs hoses and it is all hooked up correct. So if it is full or low on fuel it has no pressure issues.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
September 14, 2009 - 05:17:51 AM »
you should have a vent line up to the valve cover breather , , it should not be blocked anywhere between the tank & valve cover
Logged
mopar440
Jr. Member
Reply #4 on:
September 15, 2009 - 03:54:43 PM »
thanks for info on tank , was going to start taking apart, will check that, thanks again !
Logged
daveh
Full Member
Reply #5 on:
September 15, 2009 - 04:11:43 PM »
Anyone have a diagram of the line that is to go up to the valve cover?
Logged
71 DEPUTY
Full Member
IF YOU CAN'T DODGE IT--RAM IT!
Reply #6 on:
September 15, 2009 - 05:15:42 PM »
it uses a 3 port breather cap- see attachment.
Logged
http://www.cardomain.com/id/71_deputy
daveh
Full Member
Reply #7 on:
September 16, 2009 - 10:13:34 AM »
Awesome thanks
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
