Author Topic: Cig Lighter problem  (Read 2527 times)
Offline Moparinho
  • "Too many Ferrari and Lambo around me..."
Cig Lighter problem
« on: September 13, 2009 - 02:46:38 PM »
I have problems to make the cigar lighter working.  I connected the original plug to the back of the lighter but I no have idea to how grounding the lighter socket.  Should it be grounded through the dash frame ?
Paolo (Italy):
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383  (coming soon...)
'65 Shelby Cobra 427 Replica
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
Re: Cig Lighter problem
« Reply #1 on: September 13, 2009 - 04:09:38 PM »
Yes, it grounds through the frame.
I'd put a voltmeter on the plug wire to see if it has power. If it does, then check the resistance (with an ohmmeter) of the lighter body to the car ground. If it is greater than zero, there is a grounding problem.
Let us know how these work out, and we can proceed from there.
Offline Moparinho
« Reply #2 on: September 13, 2009 - 04:47:04 PM »
there is power in the plug wire but no in the socket that is attached on the frame.  Using a test wire I've connected the lighter socket with the frame of the instrument panel and the lighter starts to work.  I should have power on this side of the frame too ?
Paolo (Italy):
Offline BruteForce
« Reply #3 on: September 13, 2009 - 05:31:11 PM »
I just checked mine to be sure, there is no ground strap on it.
The grounding is done through the case of the lighter to the case of the socket to the lighter sheet metal assembly to the dash frame. I'd start looking at those with the grounding test lead one by one. When you find which interface is bad, it's probably corrosion or too much paint.
Offline Moparinho
« Reply #4 on: September 13, 2009 - 05:56:41 PM »
do you have the same situation on the back  ?  My concern is that something is missing on the back thread of the socket... :clueless:
Paolo (Italy):
Offline BruteForce
« Reply #5 on: September 13, 2009 - 07:43:46 PM »
That looks like it.
« Reply #6 on: September 14, 2009 - 05:22:19 AM »
I agree , there is a round center pin for power & it grounds through the dash frame
Offline Moparinho
« Reply #7 on: September 14, 2009 - 07:05:50 AM »
so, I definitely don't have ground on that side of the frame.   I have ground only on the instruments cluster panel  frame  (and only when the headlamps switch is turned on).
Any ideas ?
Paolo (Italy):
Offline the_engineers
« Reply #8 on: September 14, 2009 - 11:04:19 AM »
I bought a replacement lighter receptacle that has a tab for a spade connector.  I attached a ground wire to that.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #9 on: September 14, 2009 - 11:53:42 AM »
Any ideas ?
Thats tough to understand. Could you rephrase?
Offline Moparinho
« Reply #10 on: September 14, 2009 - 01:06:20 PM »
using the tester, if I connect one wire in to the lighter plug and the other on the lighter frame I do not have any power.  But if I connect one wire in to the lighter plug and the other wire on the frame where the instrument panel is attached on, I have 12V on the display of my tester (only with headlights on).
Paolo (Italy):
« Reply #11 on: September 14, 2009 - 01:13:19 PM »
Let's take this one step at a time:
Does your lighter work with the lights on?
Do you have continuity (lack of resistance (Ohms)) between the lighter frame and the dash frame?
Brooks
1971 'Cuda 360
Offline Moparinho
« Reply #12 on: September 14, 2009 - 04:54:53 PM »
No, it doesn't work with the lights on.  It was only a test I did connecting the lighter socket to the instrument panel, and the lighter works so when the lights are on.
Yes, I have continuity between lighter frame and dash frame.
Paolo (Italy):
« Reply #13 on: September 14, 2009 - 09:58:00 PM »
:clueless:
Take a look at the attached pic.  If you pass all of the tests listed, your push-in ligher itself is the culprit.
Brooks
1971 'Cuda 360
« Reply #14 on: September 14, 2009 - 10:53:25 PM »
A picture's worth a thousand words. Nice job engineers :2thumbs:
