Author Topic: Electric Fuel Pump  (Read 6315 times)
Offline pink panther
Re: Electric Fuel Pump
« Reply #15 on: September 18, 2009 - 10:01:16 AM »
Holley blue is high pressure pump that needs regulator just before the carbs. But it usually comes with one.
Return line is not needed.
Holley works but its pretty noisy if you dont get it in very good place. If you think its too noisy, try mallory.
It is noisy for sure, Mine is on the left frame rail, and I do have a pressure regulator mounted to the passenger inner quarter to feed the carbs
moparniac
« Reply #16 on: September 18, 2009 - 10:07:30 AM »
I put on the  holley hP gerator model... real quite and great for the street....  :working:
Offline kmyles
« Reply #17 on: September 18, 2009 - 11:23:42 AM »
Well I finally got the pump in...the wife was away so daddy will play!! Honey do list out the window...kids fast asleep...me....who needs sleep!!! :sleeping:
Couple of questions.
1. My pump dosn't have a return line on it so What will I do with the inlet on the sender, cap it off??
2. Where do I hook up the vapor line that runs up to the front of the car??
Tonight I will wire it in and finish hooking the lines up  :2thumbs:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline kmyles
« Reply #18 on: September 18, 2009 - 11:28:12 AM »
Would love to post some pics but I am getting the error uploader full :pullinghair:
_________
Kevin
Offline kmyles
« Reply #19 on: September 18, 2009 - 12:06:03 PM »
Here ya go!
_________
Kevin
moparniac
« Reply #20 on: September 18, 2009 - 12:10:50 PM »
Yes cap off the return line and I took out all my junk vapor lines and capped that stuff off except I ran a peice of fuel line into the frame rail back there for venting...  I would still have a good filter before the pump those junk azz socks can come off ya know... Get a fuel pressure gauge for the reg also:working:
Interesting waterpump neck....  :working:
« Last Edit: September 18, 2009 - 12:15:29 PM by StRoKer »
« Reply #21 on: September 18, 2009 - 01:11:41 PM »
Interesting waterpump neck....  [/quote]
Mine had that too, motorhome engine.
Offline 71Plym
  • 1971 B2 Cuda
« Reply #22 on: September 18, 2009 - 02:40:28 PM »
I have tried 2 different Holley HP 150 gph pumps and both would fail after running for about 1/2 hr.  Then they would start working again the next day.  Unrealiable.  I have the pump mounted on the pass side frame rail about even with the middle of the gas tank (only place I found to miss the 3" exhaust, dana, springs, shocks, etc).  Holley Tech was adamant that the pump needs to be mounted below the bottom of the gas tank and claimed my mounting location was causing the pump to cavitate, overheat, and then fail in thermal overload.  The pump only pushes, it can't pull.
I now run an Aeromotive pump in the same location and no further problems.  The Aeromotive is noisier than the Holley but it works.
Offline the_engineers
« Reply #23 on: September 18, 2009 - 03:36:32 PM »
I made an isolator mount so that my pump does not have a steel-to-steel connection with the car.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline ShelbyDogg
« Reply #24 on: September 23, 2009 - 11:19:29 AM »
I noticed that water pump too.  Used on 400s and late 440s.  Have you had a radiator in the car yet?
Offline kmyles
« Reply #25 on: September 23, 2009 - 11:20:21 AM »
Where do I hook my vapor line in the engine bay???
_________
Kevin
Offline kmyles
« Reply #26 on: September 23, 2009 - 11:24:28 AM »
Yeah before i stripped the car down there was a 22inch rad in there, hopefully later on down the road I will get a 26inch. The 22 worked before the rebuild and I'm sure will work for me until I get the 26! :2thumbs: As for the waterneck I got that from MotorChrome.com
_________
Kevin
Offline ShelbyDogg
« Reply #27 on: September 23, 2009 - 11:32:38 AM »
When you switch to a 26, change your water pump to the driver's side entry type. You'll get better cooling if the inlet and outlet are on opposite sides.
My 71 vent line vent to my valve cover breather.
Offline kmyles
« Reply #28 on: September 23, 2009 - 11:34:09 AM »
Do you have a picture of how yours looks???
_________
Kevin
Offline ShelbyDogg
« Reply #29 on: September 23, 2009 - 11:37:57 AM »
I don't because when I pulled my engine, I found out that it was a newer year than my car. It was swapped and the hose was left off.  Someone here might have a service manual handy. Mine is at home.
