Author Topic: Electric Fuel Pump  (Read 6316 times)
Offline 73EStroker
Re: Electric Fuel Pump
« Reply #30 on: September 23, 2009 - 09:04:48 PM »
Kmyles - if you have a fuel vapor or return line then I suggest you use it. Take a look at the attached Mallory site link as they explain and show some fuel line schematics. What you also need is a fuel line regulator. This would be mounted on the return side of the carburettor back to the tank. So the advantage is you get full fuel volume to the carb and the pressure regulator knocks the pressure down to 5-7PSI. Also you get constant fuel flow (IE no surges when you put your foot in it) and the circulating fuel ensures a cooler fuel supply on hand in the hot summer days. Anyway take a look at the link and see if it can help you decide.
http://www.malloryperformance.com/ProductsListByMinID.aspx?minID=2206&majID=220&selection=0&minselection=4
Barry (Salmon Arm)
Offline kmyles
« Reply #31 on: September 24, 2009 - 10:32:26 AM »
The regulator or pump that I have dosn't have a return line on it so for now I will hook the vent line to the valve cover and hook the regulator up before the carb. In the event that I end up needing a return line (which I think I will( I will use the vent line and vent my tank via the four vent lines at the top of the tank. Let's all hope for the best!! Said it befoe but I am going to try an start it this weekend :scared: Wish me luck :2thumbs:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline ShelbyDogg
« Reply #32 on: September 25, 2009 - 12:19:01 AM »
Do you have a picture of how yours looks???
Kevin,
there is a picture from the book in this thread:
http://www.cuda-challenger.com/cc/index.php?topic=61990.0
Offline 1971Challenger
« Reply #33 on: September 25, 2009 - 10:32:12 AM »
Hey Guys,
I too am about to run an electric fuel pump and return line. does it matter which of the 4(5)? vapor lines I use to send the fuel back in to the tank. The vapor return line I have now seems to connect to the filler neck?  (sorry if this is considersed a hijack!)
I have tried to find a "pin-out" of line vapor lines, but no luck.
Thanks!
//Tom
"Understeer" is when you hit the fence with the front of the car. "Oversteer" is when you hit the fence with the rear of the car. "Horsepower" is how fast you hit the fence. "Torque" is how far you take the fence with you.
Offline kmyles
« Reply #34 on: September 25, 2009 - 10:49:57 AM »
Hey Guys,
Thanks!
//Tom
My return spout was on the sending unit. See my pics above :2thumbs:
_________
Kevin
Offline 71Plym
  • 1971 B2 Cuda
« Reply #35 on: September 25, 2009 - 05:56:00 PM »
Note that, based on the referenced Mallory web site (and others), the return line is recommended to be as big or bigger than the supply line.  I don't think the vapour lines are that big.
Offline matt63
« Reply #36 on: September 25, 2009 - 10:02:27 PM »
Depending which regulator you have you may or may not need a return to tank line.  Mallory has both kinds.  If you have the return to tank style you should run fairly large return line ie 5/16 min.
Matt in Edmonton
'68 Valiant
