Author Topic: Body numbers  (Read 3277 times)
Offline Purple73Cuda
Body numbers
« on: September 17, 2009 - 12:00:49 PM »
Is there anyway to find out model of car and engine size from just the body numbers? I found a '74 Barracuda/'Cuda shell with just the cowl and radiator support numbers. There is no broadcast sheet, no fender tag and no VIN tag.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Re: Body numbers
« Reply #1 on: September 17, 2009 - 12:15:02 PM »
The entire VIN isn't stamped on the cowl or on the rad support.  Just the sequence #.
How do you even know it's a 74?
Is there a title to the car?  That will tell you what you want to know.
Re: Body numbers
« Reply #2 on: September 17, 2009 - 12:28:49 PM »
The # is B4******. It has no title.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Re: Body numbers
« Reply #3 on: September 17, 2009 - 12:45:02 PM »
Is it just the shell or are there other components still bolted to it?  Is the K-member with the torsion bars still on it.  If it has the small bars it won't be a Cuda.
What about the rear suspension?  Are there holes in the frame where the rear swaybar brackets would bolt?  Could you get the HD suspension on just a Barracuda?
Where the tail panels painted black on all models or just the Cuda?
Looking at these things may only tell you if you have a Cuda or Barracuda.  You still don't have any way of telling if it is a 318 or 360 car.
Offline kissalien
Re: Body numbers
« Reply #4 on: September 17, 2009 - 01:08:25 PM »
The year will be stamped. As reponded B4 in this case. B=Hamtramck which was the only E-body plant after 1970. 4=1974
Re: Body numbers
« Reply #5 on: September 17, 2009 - 01:11:42 PM »
What sizes are the t bars? As I understood the t bars are the same between 318 and 360 cars. I could be wrong.How about rear springs? Are they different? I will have to do some research on the '74 cars. I thought that front and rear sway bars were standard equipment.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Re: Body numbers
« Reply #6 on: September 17, 2009 - 01:20:54 PM »
I'm going on what I know for Challengers so I don't know how much of that translates to the Cuda.
The standard Challenger with a 318 had smaller T bars in other years so I assumed the 74 would also.  The 318 Rallye Challenger had the same T bars as the 340/360.
The rear swaybar was only available on on the Rallye.  It was supposed to be just the 340 but alot of 318 Rallyes also had the rear swaybar.(mine does)  I don't know if HD suspension was available on the base modle or not.
Alaskan_TA
Re: Body numbers
« Reply #7 on: September 17, 2009 - 08:26:49 PM »
In most cases, if you apply for a state issued VIN tag, your state DMV or BMV will contact the FBI to get the full VIN of what it was based on the body numbers.  :2cents:
Offline hebeegbz
Re: Body numbers
« Reply #8 on: September 18, 2009 - 11:48:48 PM »
dmv good call , the 2nd and 5th didgit some  times on a dealer search will also come up if the car hasnt been of the road many years . I have to ask about drill holes on the rear panel ie trim and emblems ,body stripes will show on cars that get a chemical strip along the qtrs the paint wont lift as fast if the car ever had a stripe even after its been removed unless previously blasted or sanded . :)
thread gone in 60 seconds
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Body numbers
« Reply #9 on: September 19, 2009 - 07:13:02 AM »
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline hebeegbz
Re: Body numbers
« Reply #10 on: September 20, 2009 - 10:33:53 PM »
