Author Topic: 3 Row Radiator for 340 - Need Recommendation  (Read 9790 times)
Offline cwestra
« on: September 17, 2009 - 02:37:57 PM »
I need to get a 3 row radiator for my '70 Cuda 340 (T/A engine).  Any recommendations on where to go for one?  I contacted 1-800-RADIATOR who quoted me on a steel (like original) and aluminum.  Any advice would be greatly appreciated.
Corey - in Northern Indiana
Offline matt63
Re: 3 Row Radiator for 340 - Need Recommendation
« Reply #1 on: September 17, 2009 - 05:34:05 PM »
There are a lot of choices.  Just look in the Summit catalogue for an idea.  Perhaps you could narrow it down to steel or aluminum / stocking looking and stock dimensions or something larger.  You must of course specify if you need a tranny cooler.  Do you want a stock shroud to fit or are you considering electric fan/s?  I'm assuming that with a T/A it would be as close to stock as possible in which you should be looking at Mopar reproduction rads or a restored original T/A rad.  Hope this helps a bit.
Matt in Edmonton
'68 Valiant
« Reply #2 on: September 18, 2009 - 12:11:56 AM »
original rads were brass ,the correct rad will be a 26 " wide
Offline LAA66
« Reply #3 on: September 18, 2009 - 10:08:16 AM »
 I bought a Modine a few years back for my 340 Challenger. It looks and fit just like the original.
Offline 2TAGS
« Reply #4 on: September 18, 2009 - 01:50:20 PM »
If you want an original looking radiator, Glen-Ray should be able to help you out.  I talked to them at the Mopar Nats and they were very friendly, helpful and knowledgable.  Couldn't find a website but here is a link to their info.   :thumbsup:
http://www.imcool.com/shops/glenrayradiators/index.html
1971 'Cuda 340
Offline cwestra
« Reply #5 on: September 20, 2009 - 09:01:32 PM »
I appreciate the advice and leads.  The radiator in my Cuda is a #2998948 and is not correct for my car.  I was going to go ahead and use it for now but just found out it failed a pressure test at 15 psi (small leak in a center core near top).  A couple of questions.
Is it possible to have the leaky core tube soldered up or is this not worth the effort and loss of flow, particularly if other tubes may not be far behind?
What should I expect to pay to have this re-cored?
About what is it worth in it's present condition (very clean and straight)?
The part I really need is a 2998974.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #6 on: September 23, 2009 - 10:51:29 AM »
I took a picture of my factory 26" SB radiator down to OReilly's and flipped through there book unil I found what I wanted.
I'm sorry I didn't write down the application, but it was 4 row "Heat Buster" radiator for a different mopar application.  It was ~1" taller then factory, and I had to drill one new hole in the bracket, but otherwise it looked totally stock.  I just pushed it a little farther down so the top was close to the factory location and drilled the holes.
I think it was just under $200.   I never had any problems with it, which is saying a lot living here on the face of the sun.....Austin, Tx.
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline cwestra
« Reply #7 on: September 23, 2009 - 05:26:31 PM »
That price sounds very reasonable.  You don't happen to have a picture of it do you?
Offline miketyler
    • www.miketyler.net
« Reply #8 on: September 23, 2009 - 08:00:18 PM »
X2, got any pics or part number?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #9 on: September 23, 2009 - 08:15:05 PM »
http://www.pliii.com/?top
Part #433619
    * Product details
    * Interchange details
    * Application details
Part Number
    433619
Make
    CHRYSLER
Construction
    Copper Brass
Core Size
    17 1/2 x 26 1/4 x 2
Number Of Rows
    3
Mount Type
    Flange
Inlet Location
    Top Left
Outlet
    1 3/4
Outlet Location
    Bottom Right
Tank Inlet Size
    3 X 26 3/4
Tank Outlet Size
    3 X 26 3/4
Hose Inlet Size
    1 1/2
Transmission Oil Cooler
    10
« Reply #10 on: September 23, 2009 - 08:17:54 PM »
http://www.napaonline.com/NOLPPSE/%28S%28fzpwwy55qgqorb45b45tdozg%29%29/Detail.aspx?R=NRS374_0249173282
Part:      NR 374
Product Line:    Spectra Radiators
This part can only be purchased from your local NAPA Auto Parts store.
Features & Benefits
Manufactured w/ Industry Leading Quality Components Using World Class Process
Attributes
Comments : Brass Tanks w/ Copper Brass Core
Radiator Core Size : 17 1/2" x 26 1/4" x 2" (3 Row)
Radiator Inlet Connector Size : 1 1/2" Top Left
Radiator Inlet Header Size : 3" x 26 3/4"
Radiator Make : Chrysler
Radiator Mount Type : Flange
Radiator Oil Cooler Size : 10" Transmission
Radiator Outlet Connector Size : 1 3/4" Bottom Right
Radiator Outlet Header Size : 3" x 26 3/4"
Offline cwestra
« Reply #11 on: September 23, 2009 - 09:29:47 PM »
Part:      NR 374
Features & Benefits
Attributes
This one looks good.  Any idea what they sell for?
« Reply #12 on: September 23, 2009 - 09:37:09 PM »
No price, states something about sold in store only, just call your local NAPA.  Based on what I've seen $2-300.00
Offline cwestra
« Reply #13 on: September 24, 2009 - 04:10:06 PM »
Just talked to NAPA today.  They found the radiator P/N but said they could not get it anywhere.  Price would have been $404.  Good looking radiator though.
« Reply #14 on: September 24, 2009 - 04:35:53 PM »
Summit carries the Proliance Ready-Rad line, although they do not list the 3-row...Call them & see if they can get a 433619
Their price on the 2-row is decent
http://www.summitracing.com/parts/PLI-433511/
