Author Topic: 3 Row Radiator for 340 - Need Recommendation  (Read 9788 times)
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
Re: 3 Row Radiator for 340 - Need Recommendation
« Reply #15 on: September 24, 2009 - 05:30:21 PM »
That price sounds very reasonable.  You don't happen to have a picture of it do you?
I'm afraid this is all I have of it.  As you can see it sticks up slightly more than stock, but I had no problems closing the hood.
p1010064
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #16 on: September 24, 2009 - 08:13:41 PM »
Glen Ray actually makes the repo radiators numbered n date coded or no numbers, pricey but nice around 650-700
http://www.rosevillemoparts.com/product_info.php/p/70-74-b-e-body-26-3-core-radiator/products_id/1692
this is the e-body 26 3 core from them, I do have these in stock. but again $$
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline cwestra
« Reply #17 on: September 24, 2009 - 08:55:22 PM »
Sure is pricey.  I'm sure he gets a couple hundred to put the P/N in.  Good to know there available though.
Corey - in Northern Indiana
Offline mrob
« Reply #18 on: September 25, 2009 - 10:47:28 AM »
cwestra,
Proliance (used to be Modine) makes a brass replacement radiator with stamped tanks. It looks pretty close to original but obviously doesn't have the Mopar part number stamped on the upper tank.
Here are the specs taken from the website:
Part Number 433619
Make CHRYSLER
Construction Copper Brass
Core Size 17 1/2 x 26 1/4 x 2
Number Of Rows 3
Mount Type Flange
Inlet Location Top Left
Hose Inlet Size 1 1/2
Outlet 1 3/4 Outlet
Location Bottom Right
Tank Inlet Size 3 X 26 3/4
Tank Outlet Size 3 X 26 3/4
Transmission Oil Cooler 10
Make  Interchange Part  Proliance Part
CHRYSLER  2998948  433619
CHRYSLER  2998949  433619
CHRYSLER  2998974  433619
CHRYSLER  3443969  433619
CHRYSLER  3443970  433619
CHRYSLER  3443971  433619
CHRYSLER  3574624  433619
CHRYSLER  3574626  433619
CHRYSLER  3574627  433619
CHRYSLER  3673027  433619
CHRYSLER  3673924  433619
CHRYSLER  3673927  433619
DPI  374  433619
SPI  374  433619
Make  Model  Years
DODGE  CHALLENGER  1970-1973
DODGE  CHARGER  1970-1973
DODGE  CORONET  1970, 1972-1973
PLYMOUTH  BARRACUDA  1970-1973
PLYMOUTH  CUDA  1970-1973
PLYMOUTH  ROADRUNNER  1972-1973
I have one in my 73 Cuda 340 and it does a good job cooling my motor.
Hope this helps.
Offline Purple73Cuda
« Reply #19 on: September 25, 2009 - 01:19:15 PM »
I bought a radiator from Glen Ray at the Mopar Nats this summer. Bob was excellent to talk to. He was very patient, knowledgable and friendly. The radiators are beautiful! As far as I know they are the only people licensed by Chrysler to reproduce radiators. They also offer a high efficiency core which has more fins per inch than the stock setup.
The radiator came packaged very well. The correct radiator cap, radiator attaching bolts and u nuts and the shroud attaching bolts and u nuts were included in the radiator box.
Yes they are pricey but in my opinion worth it! I would not hesitate to recommend them. I will defintely deal with them in the future.
If you can find an old time radiator shop they can probably recore the radiator you have. My old radiator had a few tubes soldered shut because of leaks. I had no problem with overheating.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
