Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Are pistons tapered?
« previous
next »
Print
Pages: [
1
Author
Topic: Are pistons tapered? (Read 1026 times)
priderocks
Jr. Member
on:
September 17, 2009 - 04:49:32 PM »
I have a set of Arias forged pistons, std. bore, for a 383. When I put my dial calipers across them, it appears the skirt (if that's the right term) of the piston is a larger diameter than the top of the piston. Is this normal?
Logged
matt63
Sr. Member
Re: Are pistons tapered?
Reply #1 on:
September 17, 2009 - 05:29:33 PM »
I think so. I'm a little rusty on this but the piston should be measured up and down below the rings (skirt). If measured above the rings it will be much smaller.
Logged
Matt in Edmonton
'68 Valiant
72cudamaan
Resident
Reply #2 on:
September 17, 2009 - 08:00:47 PM »
Yes that is correct. Actually a piston skirt is oblong and tapered. The piston manufacturer always marks on the box or puts a tag in the box detailing where exactly to measure the piston for an accurate actual dimension. This info is to be used by the machinist so he knows what size to finish hone the bore to.
Logged
If I cant fix it, it's broke
Andy (phukker whither)
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
September 18, 2009 - 12:13:08 AM »
the piston is oval for expansion & the top is slightly smaller diameter than the skirt
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
