Author Topic: Rear end gears  (Read 960 times)
Offline gunmetal
Rear end gears
« on: September 19, 2009 - 08:17:50 AM »
I have a 72 challenger with a 340 running about 400 hp with a auto tranny.  Looking for some advice on what rear end gears I should put in, daily driver that I'd like have plenty of torque to the rear wheels.  I'm being told to put 3.73's in for an all around ratio
Offline 73Chally
Re: Rear end gears
« Reply #1 on: September 19, 2009 - 08:50:28 AM »
Will you see much highway driving?  If not, I would go up to 3.91s (That's what I have with my 440-6).  If you will be driving on highways on a regular basis, I would look at 3.55s.
Re: Rear end gears
« Reply #2 on: September 19, 2009 - 10:47:29 AM »
Re: Rear end gears
« Reply #3 on: September 19, 2009 - 12:11:48 PM »
Another factor is your tire size. What diameter are they? If you are running some low profile wheels, I would look at 3:55's.
Offline Katfish
  • 70 Challenger
Re: Rear end gears
« Reply #4 on: September 19, 2009 - 12:33:56 PM »
I went from 3.55 to 3.73 when I changed from 8.75 to Dana.  I'm very happy with the new gears.  Tire size does need to be factored in.
Check out this post, I have a spreadsheet that lets you enter everything for comparison.
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=5413584&Searchpage=2&Main=5412888&Words=cnxt&topic=&Search=true#Post5413584
Offline gunmetal
Re: Rear end gears
« Reply #5 on: September 19, 2009 - 04:36:22 PM »
15 inch tires Goodyear T/A's.  Sounds like the 3.73 gears will be fine. I don't want to go so low that the motor runs at 3,000+ rpms at highway speed.
Re: Rear end gears
« Reply #6 on: September 19, 2009 - 04:40:03 PM »
Check out this site a mod posted for us a few months back. It's fun and pretty close
http://vexer.com/68rt/speed.html
Offline gunmetal
Re: Rear end gears
« Reply #7 on: September 19, 2009 - 05:04:23 PM »
That is "AWESOME".  Thank you...
