Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
6 pack jettings
« previous
next »
Print
Pages: [
1
Author
Topic: 6 pack jettings (Read 570 times)
340_6pak
Jr. Member
6 pack jettings
on:
September 20, 2009 - 09:21:12 PM »
Guys;
I am tuning a 6 pack on top of a 340, and I ran across this item on the web. It talks about replacing the metering blocks with ones that have jets that can be changed without taking the fuel bowl off. (not promax)
Here is the link:
http://www.hotrod.com/techarticles/speed_block_quick_jet_changes/index.html
and a quote from the article.
Instead of mounting the jet in the metering block, Hammel created a brass cartridge that screws in from the top of the block. The bottom of the cartridge holds the jet in place inside the metering block in roughly the same location as the original Holley design. The beauty of this is that the cartridge can be removed from the Speed Block without removing the float bowl. This makes for incredibly quick jet changes.
Has anyone ever tried these?
Logged
73 Challenger
340 6pak
Chryco Psycho
Administrator
C-C.com Guru
Re: 6 pack jettings
Reply #1 on:
September 21, 2009 - 12:59:14 AM »
yes they work just fine
Logged
340_6pak
Jr. Member
Re: 6 pack jettings
Reply #2 on:
September 21, 2009 - 01:59:49 PM »
Chryco;
I just reread the instructions for this product and it says:
"The metering plate is installed between the carburetor's fuel bowl and original metering block. "
http://www.dougherbert.com/adjustajetkit-p-19502.html
Shouldn't that say 'instead of', or does the original metering plate stay in there? If it does, do I remove the original jet?
Logged
73 Challenger
340 6pak
340_6pak
Jr. Member
Re: 6 pack jettings
Reply #3 on:
September 21, 2009 - 02:16:38 PM »
On second thought, nevermind. This part has been discontinued according to the tech line.
Bummer.
Logged
73 Challenger
340 6pak
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
6 pack jettings
