Author Topic: Line up from the crank and power steering pulley  (Read 1154 times)
Offline 4yuckfous
« on: September 21, 2009 - 05:04:53 PM »
I have a problem with the line up from the crank pulley and the steering pump pulley.
The steering pump is about 1 cm (1/2") to far in front.
How can I adjust this mistake?
Can I put some washers under the crank pulley?
Thanks for a feedback
Greetings from Switzerland
Andrea
The streets don't get wider, if you drive slower !
Offline 422STROKER
  • Member Since 6/3/06
Re: Line up from the crank and power steering pulley
« Reply #1 on: September 21, 2009 - 05:15:45 PM »
Do you have a pic?  What type of pump and block?
1/2" is too much, something isn't right there.  How about the crank pulley, is it stock?
Tom
Tom
wagesofsin
« Reply #2 on: September 21, 2009 - 06:10:58 PM »
you may have the wrong crank pulley.
and as tom mentioned, a pic would be most helpfull.
Offline 4yuckfous
« Reply #3 on: September 22, 2009 - 01:01:33 AM »
Here some pics
« Reply #4 on: September 22, 2009 - 01:22:07 AM »
you cannot put washers behind the crank pulley without causing problems , you either need a different crank & or PS pulley or try pressing the PS pulley on backwards
Offline 4yuckfous
« Reply #5 on: September 22, 2009 - 03:07:51 PM »
o.k. I understand, without washers!
what for other possibilities do I have ?
I can't order 10 different pulleys in US.....
Offline dutch
« Reply #6 on: September 22, 2009 - 03:21:08 PM »
I`d visit a local turn / mill shop with that problem.  just ask them how much for making one that fits...  and try some different shops too, that might make a big difference in price...  :2cents:
*** Bart ***
Offline 422STROKER
« Reply #7 on: September 22, 2009 - 05:54:11 PM »
Looks like the crank pulley is wrong?  The PS pulley looks ok to me.
Tom
Where did you get the aluminum pulley?
Tom
Offline 4yuckfous
« Reply #8 on: September 23, 2009 - 12:52:41 AM »
@ Tom
I get the parts from our US trip last year.
I bought the pulley from Jerrys Auto Supply, WA.
If I lock your and my pictures, both pulley's are on axis.
Mine have a space from about 2-3 mm in back but not 10 mm. :clueless:
This 2-3 mm space is to less.
I think I have to produce a new one with the ~10 mm off axis to the rear side.... :pullinghair:
Offline 422STROKER
« Reply #9 on: September 23, 2009 - 03:43:38 PM »
Try to get some measurements of the crank pulley, I have a couple lying around in my pile I can see if I have a proper crank pulley for you.  I can check your measurements vs mine.
Tom
Tom
Offline 4yuckfous
« Reply #10 on: September 25, 2009 - 12:22:39 AM »
Good morning Tom
I was yesterday on a "turning lathe" shop.
They make me a new pulley.
The offset is incredibly, 10,8 mm.
If that doesn't work, I will let you now.
Thank you for your support
Offline 422STROKER
« Reply #11 on: September 26, 2009 - 07:50:09 AM »
Ok, hope you get it sorted out soon.
Tom :2thumbs:
Tom
Offline 4yuckfous
« Reply #12 on: November 15, 2009 - 02:00:39 AM »
Thank you guys.
Now I think it looks o.k.
Offline 422STROKER
« Reply #13 on: November 15, 2009 - 01:31:53 PM »
Looks good.
Tom :2thumbs:
Tom
