Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Hellwig rear sway bar install? Pictures anyone???
« previous
next »
Print
Pages: [
1
Author
Topic: Hellwig rear sway bar install? Pictures anyone??? (Read 613 times)
lime73
Jr. Member
on:
September 21, 2009 - 06:43:49 PM »
Does anyone have pictures of a Hellwig rear sway bar install. Their instructions SUCK and the pictures on the photocopied sheet are useless. Any help would be appreciated. Thanks
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Re: Hellwig rear sway bar install? Pictures anyone???
Reply #1 on:
September 21, 2009 - 07:30:06 PM »
LMK if you got the PM with the pics.
Tom
Instructions do stink, just get it in there loose and adjust until you're happy.
Logged
Tom
lime73
Jr. Member
Reply #2 on:
September 21, 2009 - 07:42:57 PM »
thanks Tom PM sent frame ties in the way for me. already welded in and boxed. Was there a threaded hole under your frame tie??
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #3 on:
September 21, 2009 - 07:45:30 PM »
No, the kit comes with that 6" long rod and a nut welded on the end, if you look at the framerail there is a hole to slide it in and use the rod to hold it in place while starting the bolt.
Tom
Logged
Tom
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #4 on:
September 21, 2009 - 07:47:36 PM »
You may be able to use the frame ties in some way if they are in the way.
Tom
Logged
Tom
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
