Author Topic: Rear Window Installation Procedure Needed  (Read 4182 times)
Offline cwestra
« on: September 22, 2009 - 02:00:44 PM »
Anyone have the procedure for installing the rear window on a '70 Cuda?
Corey - in Northern Indiana
Offline 426HEMI
Re: Rear Window Installation Procedure Needed
« Reply #1 on: September 22, 2009 - 02:03:34 PM »
Do you have the sealer tape yet?  Get everything real clean so the sealer will stick and have the rear glass clean as well and then all you do is install the tape and then the window.  Hope this helps.   :2cents: :bigsmile:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline cwestra
« Reply #2 on: September 22, 2009 - 02:07:14 PM »
I don't have sealer tape.  The window channel is clean (car recently painted) and window is clean as well.  Where can I get the sealer and how is it applied.  Thanks.
Offline 426HEMI
« Reply #3 on: September 22, 2009 - 02:15:55 PM »
Autozone should have the sealer kits you need and follow the instructions in the kits so you do not have any leaks in the window.  It is not hard.  You may want to put like a 1/4 wedge in the bottom of the channel to make it where the window will line up properly. Some of the window tape sealers have those in there.   :bigsmile:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #4 on: September 22, 2009 - 02:46:25 PM »
The 70's used sealer tape?  My 73 just used black caulking(like is used on newer cars today) on the front and rear glass.  The glass is origonal and had never been out before.
Offline 426HEMI
« Reply #5 on: September 22, 2009 - 03:51:00 PM »
That is the same thing I am talking about.  It comes in a tape form roll form  There are several things it can be called.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #6 on: September 22, 2009 - 04:06:59 PM »
I thought it came in a tube and was applied with a gun.
Offline 426HEMI
« Reply #7 on: September 22, 2009 - 04:17:06 PM »
It can be done either way. :bigsmile:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline matt63
« Reply #8 on: September 22, 2009 - 06:05:19 PM »
On my '73 i bought a roll of the round 3M (5/16"?) ribbon sealer.  That is placed around the opening and the window is placed overtop.  It should rest on the 2 blocks that sit at the bottom of the channel.  You press on the glass until it seals/makes contact all the way around.
Matt in Edmonton
'68 Valiant
Offline matt63
« Reply #9 on: September 22, 2009 - 06:16:47 PM »
I bought the ribbon at an autoglass shop for $5 but you might be able to get it at an autobody supply specialty store.
Matt in Edmonton
'68 Valiant
Offline cwestra
« Reply #10 on: September 22, 2009 - 07:42:19 PM »
Great advice and leads you guys.  Sounds fairly simple.  Is the windshield any different?
Offline 426HEMI
« Reply #11 on: September 22, 2009 - 07:43:46 PM »
It is the same in the front also.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline 73EStroker
« Reply #12 on: September 22, 2009 - 08:49:13 PM »
You also need an etching compound to "paint" around the frame where the sealer makes contact. Do not try and put the sealer straight on to the paint. The etch I used looks like matt black paint when applied. Takes about 6 hours to dry properly. We put it on the glass as well. Makes the sealer stick to it.
Barry (Salmon Arm)
Offline cwestra
« Reply #13 on: September 23, 2009 - 06:59:00 AM »
Can I get the etching compound from the same place I get the sealing tape?
Offline matt63
« Reply #14 on: September 23, 2009 - 03:49:20 PM »
I didn't use any sealer - just the ribbon.  Some of the glass shops do use a brush on paint when they are using the urethane adhesive in a tube which is std stuff for many windshield installations.
Matt in Edmonton
'68 Valiant
