Author Topic: leaf spring bushing question  (Read 1567 times)
Offline lime73
« on: September 22, 2009 - 07:58:10 PM »
I Purchased Mopar Performance springs part #'s P4452984 & P4452985 and after I spent about an hour removing the rubber bushing I found out the poly bushings in my energy suspension kit included a front bushing measuring 2" in diameter and the eyehole in the spring only measures 1.5".  I looked on Energy Suspensions website along with Moogs and found no listing for a 1.5" poly bushing. When i was in Autozone today I had them look in their computer and the found only the 2" .  Does anybody know a supplier and part# where i can solve my prob?  Thanks -Jim
Offline 73EStroker
Re: leaf spring bushing question
« Reply #1 on: September 22, 2009 - 08:38:21 PM »
I had the same issue with my stocker rear springs. Energy kit came with large bushings and I had the smaller openings. Took them back to the seller and he replaced with what I needed. They have a catalog number for them. Autozone might not be the right retailer to find this out as the default seems to go to the 2".
Barry (Salmon Arm)
Offline lime73
« Reply #2 on: September 22, 2009 - 09:17:21 PM »
I just happened to be in autozone for something else, didnt expect them to have them.  where did you get yours.  Energy Suspensions doesnt show such a beast on their website and all the rest of my bushings are from them.
« Reply #3 on: September 23, 2009 - 01:08:04 AM »
I pruchsased the "complete" Master Bushing set from Energy Suspension which inluded 2-sets of front eye bushings.. I needed the smaller set, I guess not the 2"... See if they list in their universal section, if not submit a question to them... Odd that every listing is for the 2".
http://www.energysuspension.com/universal-products/link-flange-type-bushings-universal-mounts-isolators.html
« Reply #4 on: September 23, 2009 - 10:52:09 AM »
you could use an alum bushing in there as well
« Reply #5 on: September 23, 2009 - 02:32:21 PM »
Know a friend with a lathe? Turn down the poly to fit.
For some reason I though the 2" spring eye was used primarily before 1970 and everything else after that was 1.5
« Reply #6 on: September 23, 2009 - 04:20:40 PM »
I have a lathe if your stuck...? That's what I'd do.
