Author Topic: Changing a speedo gear  (Read 671 times)
Offline Purple73Cuda
« on: September 23, 2009 - 07:40:24 AM »
I have to change the speedo gear in my A833 to get the speedo to read more accurately.
If I jack the rear of the car up, how much gear oil will come out when I pull the speedo gear adaptor out of the tailshaft? I am assuming very little. Is that  a correct statement?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline 73Chally
Re: Changing a speedo gear
« Reply #1 on: September 23, 2009 - 09:10:52 AM »
Yes, you will not lose much.  I just did mine with it on the ground, and I lost maybe an 1/8th of a cup.  Just put a cool whip container under it and you will be fine.
« Reply #2 on: September 23, 2009 - 10:56:02 AM »
you will not lose a lot If you jack the rear of the car up , sitting level you could lose almost 2 qts
Offline 73Chally
« Reply #3 on: September 23, 2009 - 12:27:28 PM »
Okay.  I guess I lucked out.
« Reply #4 on: September 23, 2009 - 12:28:55 PM »
Great! I will jack it up.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
