Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Miloden water pump question
« previous
next »
Print
Pages: [
1
Author
Topic: Miloden water pump question (Read 614 times)
72hemi
Resident
MEMBER SINCE JANUARY 2006
on:
September 25, 2009 - 09:12:38 AM »
I just picked up a new miloden high flow water pump (part number 16250 i believe) and when i got home I was checking it out and noticed on the bottom side of the pertruding portion of the housing that holds the shaft there is a small hole in the under side of it, and I was wondering if anyone knows what this hole is for? I know
I will get a picture this afternoon.
Logged
1996 Dodge Viper GTS Coupe
Chryco Psycho
Administrator
C-C.com Guru
Re: Miloden water pump question
Reply #1 on:
September 25, 2009 - 09:22:47 AM »
it is just a vent between the brgs , all water pumps have a hole there , if the seal fails it will generally drip coolant from that hole
Logged
72hemi
Resident
Reply #2 on:
September 25, 2009 - 09:50:32 AM »
Thanks Neil, I had a feeling that it was some kind of vent, but wanted to make sure before I installed it and then discovered a nice coolant leak.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
September 25, 2009 - 10:11:53 AM »
no problem , the water pump you remove will have the hole in the same area
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
