Author Topic: Wiring  (Read 2774 times)
Offline Belltone85
  • 1973 Dodge Challenger 360 Crate Motor, Slap Stick
Wiring
« on: August 15, 2004 - 12:02:47 AM »
Has anyone ever completely redone their wiring? if so how hard of a job is it to find the wiring or did you just do it yourself?
Re: Wiring
« Reply #1 on: August 15, 2004 - 03:59:50 AM »
I guess it depends on the problem , I have built an entire harness from scratch but specific plugs & fuse boxes etc are not easily replaced . entirely new harnesses are available from a number of sources but not cheap
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: Wiring
« Reply #2 on: August 15, 2004 - 04:52:48 PM »
done as said above- but redid some on Ma Mopars problems- like- no heavy alt power thru the bulk head harness and did the headlight relay upgrade!!
RedLine
Re: Wiring
« Reply #3 on: August 15, 2004 - 10:20:32 PM »
71Deputy -  the alt wire to the charge guage- you took it out or substitute what guage wire? .... also  what headlight relay upgrade  (were doing harnesses now)  Thanks.  RL
Offline 71 DEPUTY
    • Cardomain
Re: Wiring
« Reply #4 on: August 16, 2004 - 08:16:07 AM »
I did up the gauge size from the alt to the gauge and then to the battery- just because of past experiences of wiring and bulkhead problems. also use a fusable link like the fackory used.
as for the headlight upgrade- go here as posted.
enjoy!!
http://www.dodge-charger.com/Charger/index.php?board=4;action=display;threadid=32402
