Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
bell housing clutch cover
« previous
next »
Print
Pages: [
1
Author
Topic: bell housing clutch cover (Read 794 times)
thallium
Jr. Member
I'm a llama!
on:
September 28, 2009 - 11:04:10 PM »
I just purchsed a 70 cuda. The only thing it is missing is the clutch cover that attaches to the bell housing. It's a 440 with an A833 4 speed transmission.
How can i tell which clutch cover will work? Can i measure something to find out? here is a link to the clutch covers. It's not an original engine or transmission, that is why i'm not sure which one i need. I can take a picture also if that might help?
http://jimsautoparts.com/transmission_parts.htm
it's about 1/4 of the page down listed under "4 SPEED BELLHOUSING CLUTCH COVERS"
Any help would be appreciated. Thanks.
Last Edit: September 28, 2009 - 11:05:46 PM by thallium
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: bell housing clutch cover
Reply #1 on:
September 29, 2009 - 03:02:14 AM »
put a magnet on the housing , the lager 143 tooth bel is steel , the later 130 tooth one is alum
Logged
thallium
Jr. Member
I'm a llama!
Reply #2 on:
September 29, 2009 - 08:50:10 AM »
Thanks Chryco, you're awesome!
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
September 29, 2009 - 11:35:08 AM »
the other way is to count the flywheel teeth obviously ,
Glad to help
Logged
thallium
Jr. Member
I'm a llama!
Reply #4 on:
October 17, 2009 - 04:02:45 PM »
Thanks chryco. I just finished putting the bellhousing on. It fit perfectly. Two of the holes where stripped, but 3 bolts are holding it on. Aluminum.... Never did like aluminum. It's too soft. Anyway, the cover is on and thank you for the info.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
October 19, 2009 - 02:52:18 AM »
you are welcome
Just install helicoils into the stripped holes & they will not strip out again
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
