Author Topic: Challenger Hood Hinge Question  (Read 8088 times)
Offline daveh
« on: September 29, 2009 - 09:05:40 AM »
Hey guys,
When I shut mt 71 Challenger's hood the part of the hood closest to the windshield will raise up about and inch.  I can push it down and it will stay.  My question: is it the hinge or the spring on the hinge making it pop up.  I'm heading to Carlisle and I figured I could pick up what I need there.  Thanks
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
Re: Challenger Hood Hinge Question
« Reply #1 on: September 29, 2009 - 11:24:45 AM »
IF you adjust the hinge up. It will bring the hood down.
Offline dutch
« Reply #2 on: September 29, 2009 - 01:14:35 PM »
I think you need to rebuild the hinges.  The hood pops up when the rivets have too much space in the holes.
may look like a little play on each rivet but the springs push the rivets in one direction so that adds up...
*** Bart ***
Offline 426HEMI
« Reply #3 on: September 29, 2009 - 01:17:47 PM »
The hinge is the problem it needs to be rebuilt or replaced.  They are bad about wearing and lettting the back side of the hood to pop up.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline daveh
« Reply #4 on: September 29, 2009 - 02:24:03 PM »
Thanks what do you guys think about the repro hinges?
Offline daveh
« Reply #5 on: September 29, 2009 - 02:33:10 PM »
I've found a set made by AMD for $225.00.  Not a bad deal.
Offline dutch
« Reply #6 on: September 29, 2009 - 02:46:04 PM »
sorry, I don`t have experience with them...
*** Bart ***
« Reply #7 on: September 29, 2009 - 03:26:51 PM »
:iagree: Before you buy more parts, make sure it isn't simply an adjustment.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: September 29, 2009 - 03:34:23 PM »
http://www.rosevillemoparts.com/advanced_search_result.php/keywords/hinge/search_in_description/1/sort/2a/page/5
hinges are in stock if your interested, with or with out spring. discount to members.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline nick68
« Reply #9 on: September 30, 2009 - 09:01:44 AM »
You need to adjust the hood hinges on the inner fender upward, and then snug them just tight. Then lift the hood and loosen the rear bolts and rotate the hinge as viewed from the side, tighten the bolts and check the fit. Repeat until you get the alignment right.
Trust me, it sound wrong, but until I did it, the rear portion of the hood was 2 inches too high. I even slotted the holes in the hinges.
So the secret is to raise the front of the hinge on the inner fender
"Did I mention I hate sanding ? "
Offline daveh
« Reply #10 on: September 30, 2009 - 09:13:42 AM »
Great I will try that thanks.
Offline venomus1
« Reply #11 on: September 30, 2009 - 10:22:14 PM »
the teeth inside the hinge are worn out,i took mine apart and thats what i found caused my hood to rise in the back
« Reply #12 on: October 02, 2009 - 02:56:31 AM »
 :iagree: with Nick
 if you loosen the hinge bolts & have someone lift the front of the hood to rotate the hinge it will lower the rear of the hood
 Jackie also said this at the beginning of this thread
Offline dutch
« Reply #13 on: October 02, 2009 - 08:35:20 AM »
if its an adjustment issue, would you be able to push it down and make it stay there?  :dunno:
*** Bart ***
« Reply #14 on: October 02, 2009 - 11:50:09 AM »
 Yes
