Author Topic: trunk rust removal  (Read 1026 times)
Offline vpittman
trunk rust removal
« on: September 29, 2009 - 01:57:57 PM »
Hi all,
I just bought a '73 cuda... I've never done any kind of body work, but want to give it a shot.
The trunk has a fair amount of surface rust, not all the way through, so I believe the pan is good.
What's the best way to remove this and then how should I finish it once it's removed ?
Thanks,
Victor
Offline dutch
Re: trunk rust removal
« Reply #1 on: September 29, 2009 - 02:25:13 PM »
blast & epoxy would be the way to go.  If the surface has pitting the only way to really clean it is blasting.
*** Bart ***
« Reply #2 on: September 29, 2009 - 04:40:04 PM »
There are some rust remover products on the market.  I've been using EvapoRust on small parts and it works great.  For the trunk you are going to want a "gell" instead of a liquid.  Hot Rod magazine did an article on rust removers this year.  They tested all of the major rust removers on the market and evaluated each one.  I remember there was a "gell" that worked really good.  I would think that would be a nice option over trying to clean out all the media that blasting would require. :2cents:
Offline dutch
« Reply #3 on: September 29, 2009 - 04:56:04 PM »
well,  I`m pretty oldschool when it comes to removing rust, but I guess there must be some truth in a hotrod mag. article...
*** Bart ***
Offline vpittman
« Reply #4 on: September 29, 2009 - 10:17:41 PM »
Great, Thanks for all the input... I figure I'll end up doing a bit of both
I found the Hot Rod magazine article, I'll check it out
Thanks again
Offline the_engineers
« Reply #5 on: September 30, 2009 - 12:02:24 AM »
Curious what they recommended.  I've always been a fan of Naval Jelly although I did use a rust neutralizer that actually seemed to work...
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline vpittman
« Reply #6 on: September 30, 2009 - 10:52:03 AM »
