Author Topic: Biggest/Widest Rear Wheel and Tire combo for 70 Cuda  (Read 3615 times)
Offline 7Dcuda
« on: September 30, 2009 - 09:36:05 AM »
Does anyone know the biggest rear wheel/tire combination that can be used on a stock 70 Cuda with a 8 3/4 rear end and drum brakes?
Offline 73Chally
Re: Biggest/Widest Rear Wheel and Tire combo for 70 Cuda
« Reply #1 on: September 30, 2009 - 10:14:13 AM »
The best look I have seen is a 17x8 wheel with 4 1/2" BS and 255/60-17 tires.  You might be able to get a 275 tire, but that would be pushing it.  You can go bigger on the wheels as you reduce the tire ratio (45, 40 series, etc), but I'm not a fan of the rubber band look.  You might also be able to go up to a 10" width, but again that would be pushing it and would probably require a 1" offset for the leaf.
Offline pink panther
« Reply #2 on: September 30, 2009 - 10:20:40 AM »
I have 295-50 R15 on my 73 chally with rear drums.
Here is a link from sometime ago
http://www.cuda-challenger.com/cc/index.php?topic=19470.0
« Reply #3 on: October 01, 2009 - 11:28:35 AM »
I agree , a 295 /50 on an 8 " rim should fit
Offline vinb
« Reply #4 on: October 01, 2009 - 08:18:51 PM »
I had 295/50/15's with a 8.5" wheel on the Cuda. Fit good...
Offline Doomed
  • So close...to actually finishing my 'Cuda!
« Reply #5 on: October 06, 2009 - 05:25:29 PM »
Would I be fine with a 285/ 40 on a 17x9.5?
Kyle.
"Life gets in the way of Living"
« Reply #6 on: October 06, 2009 - 05:26:30 PM »
the tire size should be fine as long as the rim offset is OK
