The horn wire is the original, I added an e-body can and a tuff wheel, did not need an adapter.
It was not doing it at first, oh for at least 4 months, and then it just started, it started only when she turned right, now its just right, left, touch the wheel it goes off. The horn wire from the wheel to the
bottom of the can is all good, it must be under the can? I'll pull it off and start tracking it, will let you guys know when i pull the can, and what I find.
BTW - THANKS for the help with my 'cuda - it all works perfect now, could not have done it without you guys! I appreciate it.
