I actaully have the vacuum advance disconnected.
I will check the mechanical advance also.
I am also going to double check my idle vacuum and compare it to the 6.5 power valve thats in there. I might need a smaller power valve.
Thanks again everyone
Sorry, you clearly stated that it was not connected in your first post. I must have stopped too soon
With regard to the power valve, what is the vacuum in Park...as well as in Drive? Also as mentioned, would not hurt to check the timing from 900 to 1300 rpm while in Park and see how much change there is.
I assume you can put your foot on the brake and demonstrate the converter is as loose as the advertised stall. I am sure after this period of time you know it is not tight at such low rpm.
It seems something is changing whether fueling, or timing when you drop it into gear.
