Author Topic: Drum Spindle Question  (Read 784 times)
Offline the_engineers
« on: September 30, 2009 - 05:01:35 PM »
Are Cuda/Challenger drum brake spindles the same as A-Body drum spindles?  Looks like A-bodies changed the size of the drum spindle in '73...would E-Bodies have already been the larger size?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Drum Spindle Question
« Reply #1 on: September 30, 2009 - 09:19:46 PM »
I cant answer that, but do you have to have drums?  I got some 70 disc brake stuff complete if you need
Offline autoxcuda
    • Spring Fling
« Reply #2 on: October 01, 2009 - 12:01:36 AM »
No, the 70-72 B/E body drums have the smaller bearing than the large bolt pattern * 73-76 A-body drum spindle. Now a 73-74 front drum challenger might be the same. Except I don't know if you could get a 73-74 Challenger with front drum brakes??
*They still made 73-76 A-bodies with small bolt pattern for very light duty applications. And those will have smaller bearings.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
« Reply #3 on: October 01, 2009 - 09:55:36 AM »
No, I have discs, but looking at some of the Wilwood and AR Engineering kits, they are designed for the late A drum spindle.
http://arengineering.com/caliper/viper/viper13.html
Brooks
1971 'Cuda 360
« Reply #4 on: October 01, 2009 - 10:24:16 AM »
True, but you can get the bearing spacer from Dr Diff with seals for around $50. Use some green Loctite for sleeves, and your in good shape.
