Smallest battery to support a 5.7
Author Topic: Smallest battery to support a 5.7  (Read 779 times)
Offline the_engineers
« on: October 02, 2009 - 02:33:13 PM »
Posting this for a friend...
He has a '34 Plymouth Street Rod that is getting a swapped 5.7 with the computer-controlled 5 speed auto, air, etc.  No modifications will be done to the motor.  The car will only be driven in fair weather, so minimal light and wiper usage.  No cold weather driving.
What is the smallest battery he should consider?  He's running the battery in it's own compartment inside the rear passenger fender.  He'd like to use a motorcycle battery if possible and go no bigger than a 650 as a worst case scenario.
Thoughts?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Smallest battery to support a 5.7
« Reply #1 on: October 02, 2009 - 06:34:41 PM »
I don't see why this wouldn't work. In theory, the battery just needs to start the car. Once started, the alternator should power the accessories. The stress test for batteries is starting in cold weather, and believe it or not, extremely hot weather.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: October 02, 2009 - 09:15:52 PM »
I would run one of these babys
http://www.kinetikaudio.com/2009/product.asp?C=1&P=KHC600
Weight: 14lbs
Ah: 20
Dimensions: 7"x3"x6.5"
Suggested Retail: $199.99
Go Fast & Have Fun...
Offline GoodysGotaCuda
« Reply #3 on: October 02, 2009 - 10:10:02 PM »
Depending on the room for motorcycle batteries, they can always be wired in parallel for double cranking power and still 12v..
1976 Dodge Warlock
Wheel & Tire Specs:Link
