Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Small block mount interchange
« previous
next »
Print
Pages: [
1
Author
Topic: Small block mount interchange (Read 542 times)
72hemi
Resident
MEMBER SINCE JANUARY 2006
on:
October 04, 2009 - 01:47:18 PM »
Yesterday I heard that the metal 318 engine mount brackets are different then those for a 340. Is that true?
Logged
1996 Dodge Viper GTS Coupe
Moparal
Permanent Resident
Re: Small block mount interchange
Reply #1 on:
October 04, 2009 - 02:23:58 PM »
1 is but I think they add a washer to the other one to make it work when they need to
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #2 on:
October 04, 2009 - 04:42:20 PM »
Quote from: Moparal on October 04, 2009 - 02:23:58 PM
I used a grade 8 nut of the proper size and it took up the distance difference perfectly.
Tom
Logged
Tom
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
October 05, 2009 - 01:48:42 AM »
left mount is different between the 318 & the 340/360
Logged
72hemi
Resident
Reply #4 on:
October 09, 2009 - 11:31:01 AM »
Which side of the block mounting tabs do the 340 brackets attach? I found an extra set of 318 mounts and I think I can modify it to work just fine by machining a spacer, thanks for the idea.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
