Author Topic: When referring to engines, what does the angle mean?  (Read 2009 times)
Offline lemming303
  • San Antonio, TX
« on: October 05, 2009 - 10:43:39 PM »
Like if you said "a 59 degree W9 engine". What does that mean?
Kevin
73 Challenger Rallye - first project
Offline the_engineers
Re: When referring to engines, what does the angle mean?
« Reply #1 on: October 05, 2009 - 10:56:08 PM »
It is the lifter angle in the lifter valley.  Stock SB Chrysler lifter angle (59*) puts a tall lifter (roller) almost into the side of the valley, so the fix is the 48* block which straightens out the angle and allows truer valve motion.  The angle change requires a custom cam amongst other issues.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #2 on: October 05, 2009 - 10:58:43 PM »
I think it refers to the angle between the left and right bank of cylinders. A 90 degree block would have the left and right bores at right angles to each other. A 60 degree block would be narrower but taller, a 120 degree block would be wide but not very tall.
At least thats what I thought it meant until I read The Engineer's reply. We could be talking about two different things that are both measured in degrees?!?
« Last Edit: October 05, 2009 - 11:05:03 PM by dodj »
Offline tommyg29
« Reply #3 on: October 05, 2009 - 11:01:06 PM »
Its like my 12th grade physics teacher once wrote on the board:
After none of us could figure it out, he translated it as:
the angle of the dangle, times the torque of the pork, divided by the mass of the ass = the integral of e to the x. Or, if you've got a juiced big block, you need a Dana 60.
:roflsmiley:
Offline matt63
« Reply #4 on: October 05, 2009 - 11:02:29 PM »
I'm going with the lifter angle answer.    Yes, for V8s the angle between the cylinders is sometimes mentioned when talking about design.  For small block Mopars however, I believe it is the lifter bore center lines because of their poor stock geometry.  The race blocks rectify this deficiency.  That's my theory.  :)
Matt in Edmonton
'68 Valiant
« Reply #5 on: October 05, 2009 - 11:07:12 PM »
:roflsmiley:
That pretty much says everything you need to know! :bananasmi
Offline gkring
« Reply #6 on: October 05, 2009 - 11:30:35 PM »
lifter angle is correct in your example. The W9 refers to the type of head. There are W2, 5, 8, 9 and various versions of each.
http://www.moparmusclemagazine.com/techarticles/engine/mopp_0310_340_engine_600_hp/index.html
http://www.moparts.org/Tech/Archive/smallblock/23.html
Greg
1970 Barracuda driver
Offline 71chally416
    • The Streetwalker
« Reply #7 on: October 06, 2009 - 12:37:18 AM »
The "LA" small block retained the lifter angle of the original Hemi, which is why it is not ideal for a Wedge motor. And not all race blocks have the improved lifter angle. :grinno:
Offline lemming303
  • San Antonio, TX
« Reply #8 on: October 06, 2009 - 10:44:55 AM »
So what difference is a Wedge motor? I thought it was just a series of engines, like LA.
Kevin
Offline moper
« Reply #9 on: October 06, 2009 - 11:31:26 AM »
Yes, lifter angle... "wedge" is a marketing name like Hemi only it means "non-hemi" shaped cylinder heads. Techincally speaking, the small block fords, SB Chevies, and anything else not using a central spark plug and in line valves is a "wedge". LA refers to the head design. So you have LA wedges, 318 Polyshperes, and Magnums(which are also wedges but use a different more modern port/chamber layout) for small blocks.
« Reply #10 on: October 06, 2009 - 11:33:46 AM »
 the small block doesn`t have the lifter angle straight with the pushrod , , the lifter leans more outward , the race blocks offer the improved lifter angle keeping the lifter & pushrod straight
 the wedge was just an nickname for the Wedge style head / combustion chamber angle to the piston
Offline Changin Gears
« Reply #11 on: October 06, 2009 - 12:31:31 PM »
But for 99.99% of engine builds this number is meaningless because its a stock block.
Offline lemming303
  • San Antonio, TX
« Reply #12 on: October 06, 2009 - 01:41:27 PM »
Thanks yall.
ChanginGears, that's a pretty cool pic in your signature line. Looks like that trans completely blew up. Bet that was pretty crazy....
Kevin
« Reply #13 on: October 06, 2009 - 02:19:08 PM »
I think you nailed it all except LA. LA was the block designation, or Lightweight A, B  the big block, and RB the Raised Block. All of these used wedge heads.  The later Magnum headed (still a wedge head) engines were still using LA blocks.
