Author Topic: How do YOU drive your SlapStik?  (Read 3200 times)
Offline TripleT
« on: October 06, 2009 - 03:49:17 PM »
The more I drive my '70 with the 727, the more I find I cannot resist downshifting from 3 to 2, then from 2 to 1 as I slow to a stop.  I always downshift manual cars I drive, and with the 727, it REALLY slows the car down and I end up having to use those spongy drums very little.  How about you?
Secondly, does anyone actually slap it up from 1 to 2 to 3 on a take off?  When I floor it, it naturally winds out and I don't think I could slap it up with better timing then it does by itself, so I never do.  Of course, I'm not racing or anything, but even if I was, I'd be scared to move it up myself, ....that R is just 2 notches up.......
-Tim
1970 Plymouth Barracuda    2000 Dodge Ram 2500
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: How do YOU drive your SlapStik?
« Reply #1 on: October 06, 2009 - 04:04:44 PM »
If your shifter functions properly it won't let you slap it up to reverse without pressing the button. I normally leave mine in drive unless I am feeling spirited driving, or if I am driving in the hills, then i play shifter.
1996 Dodge Viper GTS Coupe
Offline TripleT
« Reply #2 on: October 06, 2009 - 04:23:13 PM »
Umm, mine is apparently not functioning properly.....won't tell you how I know that....... :-[
-Tim
Offline dutch
« Reply #3 on: October 06, 2009 - 04:46:57 PM »
the few times I drove mine I really liked hitting it into 2,and 3...  :burnout:   I have 410`s so downshifting is like hitting the brakes  :eek4:   I had a slight miscalculation there the first time...  :violin:  I slowed down for a sharp turn and was shifting back to first... the rearwheels blocked and I immediatly floored it...   :burnout: :burnout: :burnout:  :woohoo:   sideways thru the turn and using the shifter what it was designed for  :ylsuper:   now that was fun  :2thumbs:   my son was hanging between the frontseats like a flag...  :netherlands:   :bigsmile:    me like slapstick...  :grinyes:
*** Bart ***
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #4 on: October 06, 2009 - 04:59:48 PM »
Like I Stole It  :burnout: :burnout: :burnout:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: October 06, 2009 - 05:21:11 PM »
Mine works well full throttle upshifts by slapping it!  Maybe take a peak at the springs and slides and lube them up.  Haven't had a problem with it going farther than it's supposed to.
Tom :2thumbs:
Tom
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #6 on: October 06, 2009 - 05:53:34 PM »
I have always manually up-shifted my Barracuda and Challenger. And I did once slap it into reverse going about 35 mph. The tranny didn't like that. My bad. I now have a reverse manual valve body, so I have to shift all the time, but I love it. Especially barking the tires! :woo:
                                               Matt B.
Matt
« Reply #7 on: October 06, 2009 - 07:15:12 PM »
Had that issue once, there was a small spring toward the rear of the mechanism that was broken about a 1-2" long 1/4" dia or so pull spring that keeps the ratchet engaged once it is pulled back to 1st or 2nd... Even if Drive is selected you can bump to neutral but never reverse.
To your question I have rarely used the tranny as a break but on the up shift side slapping the stick is what it's all about  :burnout:
« Last Edit: October 06, 2009 - 07:17:08 PM by Bullitt- »
Offline 500Stroker
« Reply #8 on: October 06, 2009 - 07:29:28 PM »
I always upshift mine from every stop.  Downshift 3 - 2 most of the time.
Online RUSTY Cuda
  • One big step foward!
« Reply #9 on: October 06, 2009 - 08:07:05 PM »
I was told there are also non slapsticks, meaning theres no lockout between gears, asked when i had a friend over why mine will go from 1'st right to neutral.
When setting up my 73 & was checking spring location(the bigger one up front) there was none in the 74  & a couple of different pieces(or lack there of) at the bottom of the shifter itself. Bought a couple a spares off ebay & there is a difference(no ratchet type thing at the bottom.
Anyone else heard  this & can confirm ? Rich.
Offline AARCuda340+6
  • Southern Ontario
« Reply #10 on: October 06, 2009 - 08:46:04 PM »
Quote
I have the same setup as Matt.
When I purchased my car in '85 the previous owner had a reverse manual valve body so I have to change gears just like a standard trans but without the clutch.
If I want to floor it down the road you can chirp the tires when shifting up to 2nd gear.
I also downshift when slowing down too so the car sounds meaner when passing through the local small towns.
It's a great way to cruise down the highway.
« Last Edit: October 06, 2009 - 08:50:09 PM by AARCuda340+6 »
You can call me RAY or RAYMOND or RAZOR or THE ZOR!
70 AAR Cuda
04 Rumble Bee
sleepychallenger
« Reply #11 on: October 06, 2009 - 10:13:36 PM »
when i had the slap stick, i manually slapped it from 1-2-3  :burnout:
Offline BIGSHCLUNK
« Reply #12 on: October 06, 2009 - 10:23:12 PM »
Depends on my mood..............................  :smokin:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline bb71challenger
« Reply #13 on: October 06, 2009 - 11:54:56 PM »
Since I love manual shifted cars I almost always pull it down into 1 and shift up and down as needed. Dont be shy, go ahead and slap it, if its working properly it will stop in second gear and then release for the slap to third. After that it will not go into neutral unless you depress the button. I have never had one fail any shift...ever.
*Brett*
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #14 on: October 07, 2009 - 01:15:10 AM »
I upshift and downshift mine, depending on if the wife is sitting in the other bucket seat.  I have more fun doing a downshift when coming to a red light.  When I finally drop it from 2nd into 1st the tires will squawk just as I come to a stop at the light.   If I'm feeling frisky I will nail it in 1st and let the back barrels take me up to around 45-50mph.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
