PUTTING INLINE QUADS ON 426 CRATE, NEED CARB SUGGESTIONS
Author Topic: PUTTING INLINE QUADS ON 426 CRATE, NEED CARB SUGGESTIONS  (Read 1479 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
« on: October 07, 2009 - 02:10:14 PM »
Here is my dilema, we are building another cuda and putting in a 426 crate engine, I am looking for suggestions on the intake and carb set up. marine stage 5 intake P4510633 with holleys, if so what carb number for the side bowl or intake P5153737 with carters/edelbrock other than the oe AFB, if so which edelbrock carter would be good and number  :thinkerg: any suggestions will be appreciated. this will also be a shaker car. thanks David
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Re: PUTTING INLINE QUADS ON 426 CRATE, NEED CARB SUGGESTIONS
« Reply #1 on: October 07, 2009 - 04:48:26 PM »
Probably the easiest set up is the new Eddy AVS Thunder series carbs on the stock AFB intake with stock carb spacing making for the easiest way to add the shaker
 if you use the holleys a Pair of the 750 Avenger series vacuum series or the 750 HP 82751 carbs will be the best bet
is this stock CI , Which cam choice , what si the application , crusing , street strip , ETc , what gear etc ?
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: October 09, 2009 - 06:52:36 PM »
426 Hemi Crate Engine - 465 horsepower
P5249667AE Crate Engine, 465 Horsepower, 465 ft.-lbs. Torque,
426 Hemi
Specifications:
· Built with All-New Components
· Heavy-Duty Cast Iron Block with Cross-Bolted Mains
· Cast Iron Cylinder Heads
· Chrome Valve Covers
· Breathers
· Stainless Steel 2.25" Intake Valves and 1.94" Exhaust Valves
· Heavy-Duty Single Valve Springs with Dampers
· Premium Material Umbrella-Type Valve Stem Seals
· 288° Hydraulic Camshaft (234° duration @ .050")- 0.499"/0.483" Lift
· Forged Pistons - 4.250" Bore, 8.7:1 C.R.
· Aluminum Dual-Plane Four-barrel Intake Manifold
· Forged Steel Crankshaft - 3.750" Stroke
· Premium Double Roller Timing Chain and Sprockets
· Front Timing Chain Cover
· Six-Quart Center Sump Oil Pan (1970-71 B- and E-Body Style)
· Spark Plug Wires
· High-Performance Electronic Distributor
dana60 with 3.73 Kiesler 5 speed, pretty much a stock tire and build. mainly for street use.
thanks for the input
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #3 on: October 10, 2009 - 02:34:56 PM »
Why don't I give you a call on monday or tuesday
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: October 11, 2009 - 03:29:12 PM »
thanks CP.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline Changin Gears
« Reply #5 on: October 11, 2009 - 06:10:03 PM »
I am quite happy, even suprised, at how well my Hemi at all RPM ranges.  It has a stock intake with the Vanke mod done.  For carbs I bought 2 new 625 afb Carter's (when they were owned by Federal Mogal), put the jets and rods in per Vanke, and replaced to tops with old AFB tops so a stock air cleaner would fit.  It drives great.
The AVS idea is pretty good though with the adjustable secondaries.
Offline dodge freak 2
« Reply #6 on: October 13, 2009 - 06:31:39 PM »
Has anybody tried to put the old AVS carb tops on a Carter carb--so you could easily adjust the secondary opening, yet have two ventureis for the secondary side.
I know, buy a edlebrock thunder carb but I'm cheap, lol.
Offline 71chally416
    • The Streetwalker
« Reply #7 on: October 13, 2009 - 06:44:58 PM »
The secret to getting a great price on a ED carb(s) is to scroll to the end of the Thunder carb listings on Jegs for the "reconditioned" carbs. They look just like new and perform the same, but are much cheaper.  :grinyes:
« Reply #8 on: October 13, 2009 - 08:21:34 PM »
Better yet go to Edelbrock web site and check their price out on reconditioned carbs. Sometimes they are better, even way better like over $100 cheaper
http://store.edelbrock.com/performerseriesandthunderseriesavscarbsreconditioned.aspx
http://store.edelbrock.com/swapmeet.aspx
« Last Edit: October 13, 2009 - 08:28:40 PM by dodge freak 2 »
