I'm in the middle of replacing the starter on my Charger and I have a couple problems. My real problem is the removal of the old starter. It is a full size starter and is impossible to remove from my 400 with headers. In my infinite wisdom I decided to try to take the starter out in pieces. So I first removed those long bolts on the end of it to try to just remove the plate at the very end. Needless to say that only succeeded in making the starter longer. So next I decided to try to remove the headers on the drivers side, I unbolt all of the bolts. Also unbolt the drivers side motor mounts and jack the motor up, headers still don't come out, the power steering box is in the way. So I remove the pressure hose in hopes to gain a little bit more room and apparently there are some o-rings on it that are now toast. My next idea was to remove the passenger side motor mounts and jack up the entire engine. So I remove the bolt by the alternator very easily, next was the further back one, bu the headers are in the way and I can't get enough leverage to loosen the bolt. I tried loosening the big bolt on the bottom of the mount and nothing it went nowhere. So here I am currently with 3 bolts to the motor mounts removed and the starter in pieces. Any advice, I'm thinking I might have to pull the motor once I get that last bolt out.
