Author Topic: Starter Installation Help  (Read 3522 times)
Offline bordin34
Re: Starter Installation Help
« Reply #15 on: October 23, 2009 - 12:58:05 PM »
How hard should it be to remove the tie rod from the center link? I have the pickle fork and am hammering away but it doesnt move at all.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline the_engineers
« Reply #16 on: October 23, 2009 - 01:44:51 PM »
Beat it like it owes you money  :horse:
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Kapteenikosmos
« Reply #17 on: October 23, 2009 - 01:51:56 PM »
It's cone type fit so if it has been there for a while, you'll probably need to pound it like hell. Neat trick is to also hammer the outside surface of the center link which is perpendicular to the tierod end. Like the outer shell where they both connect. Hopefully someone with better english can explain in more detail.
But if you understood what I mean, just hammer the pickle fork deeper between the two pieces and occasionally also hammer the center link around the areas where it contacts with the tie rod end. It should loosen up the old stuck joint and eventually pop out.
Also if it is really tight, your pickle fork might just crack (happened to me once). I have found that a claw type ball joint remover works better. One that has a screw for applying force to the contact and then hammering around the center link.
Like this, for example:
http://cgi.ebay.com/ebaymotors/Universal-Ball-Joint-Separator-Remover-Tool-HIGH-4661_W0QQcmdZViewItemQQhashZitem3ef9755267QQitemZ270473187943QQptZMotorsQ5fAutomotiveQ5fTools
Mine is just way cheaper and pretty poor in quality, but has worked for me so far.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline bordin34
« Reply #18 on: October 23, 2009 - 05:24:21 PM »
Thanks, I just went a borrowed a much heavier hammer, and then it started to rain.
« Reply #19 on: October 23, 2009 - 06:03:16 PM »
I about killed myself & the pickle fork beating on it (think I had a dham metric pickle fork)...went to the Advanced auto & "borrowed" their front end tool kit.... takes about 30 seconds each after the nut is off to pop loose.
« Last Edit: October 23, 2009 - 06:04:50 PM by Bullitt- »
Offline bordin34
« Reply #20 on: October 23, 2009 - 06:42:22 PM »
I now have discovered another problem with the car, the torsion bar. Apparently it has been rubbing on the grease zerk and now there is a noticeable indent in the torsion bar, so I am guessing I need new bars. This leads me to my next question, are the tie rods supposed to mount above or below the center link, right now mine is above. If it is on top, is there a shorter grease zerk?
