Author Topic: Replacing Accel Super Stock 8140C Coil  (Read 3843 times)
Offline kingtroll
« on: October 07, 2009 - 08:32:28 PM »
I have replaced my Accel Super Stock 8140C 12 volt coil about a year ago and now the new one seems(same model) to be giving problems. Can anyone suiggest a alternate brand as replacement. I have a 340 engine. Thanks in advance.
1974 Barracuda
Offline 73Chally
Re: Replacing Accel Super Stock 8140C Coil
« Reply #1 on: October 07, 2009 - 11:15:05 PM »
Have you tried the stock Mopar Performance coil, or are you running an MSD system?  I've never had any problems with mine.
« Reply #2 on: October 08, 2009 - 01:33:02 AM »
try the MSD Vibration Blaster , I assume you are using a ballast
Offline kingtroll
« Reply #3 on: October 08, 2009 - 06:29:38 AM »
I am not sure if I am using a ballast to be honest. I started having trouble starting my car one day and I checked if I had fuel and spark and I didn't seem to have any spark. I changed the coil by just physically replacing the one I had and then it started right up no problem. Now it seems to be giving me the same problem again a year later. I also am not using an MSD system.
1974 Barracuda
« Reply #4 on: October 08, 2009 - 08:58:23 AM »
if you have a meter you can test the coil   If close it should be good
« Reply #5 on: October 08, 2009 - 10:50:32 AM »
running without a ballast will significantly reduce the life of the coil
 the MSD coil works without using MSD ignition
Offline the_engineers
« Reply #6 on: October 08, 2009 - 11:43:57 PM »
Not trying to be funny, but do you have one of these on the firewall near the wiper motor?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline kingtroll
« Reply #7 on: October 09, 2009 - 06:53:41 AM »
Yes I do have one of those on the firewall.
1974 Barracuda
Offline kingtroll
« Reply #8 on: October 09, 2009 - 06:54:58 AM »
Thanks for posting the diagram Bullitt.
1974 Barracuda
Offline kingtroll
« Reply #9 on: October 12, 2009 - 07:58:40 PM »
Thanks for the info fellas ....I bought the MSD vibration blaster and my car cranked right up.  I hope this last longer than the Accel coil.
1974 Barracuda
