Author Topic: small or large bolt pattern for flex plate?  (Read 1623 times)
Offline shadango
« on: October 08, 2009 - 10:48:09 AM »
I am getting ready to order a TCI flexplate from Summit and need to find out if I have a "small" or "large" bolt pattern crank....
Guess i would have to actually measure it?
« Last Edit: October 08, 2009 - 11:12:17 AM by shadango »
Re: small or large bolt pattern for flex plate?
« Reply #1 on: October 08, 2009 - 10:51:48 AM »
the crank is the same bolt pattern , you need the flex plate to match the bolt pattern on the converter though
Offline shadango
« Reply #2 on: October 08, 2009 - 11:01:24 AM »
Well, thats what I thought too..
But on the TCI site, they have this info:
part#145600  All T/F  318-440  internal  small bolt circle, 5/16" bolt, 6 hole forged crank
part#145700 All T/F  318-440  internal  large bolt circle, 5/16" bolt, 6 hole forged crank
I was assuming the "bolt circle" meant the crank.   Does it mean the bolt circle on the converter?   If thats the case, the breakaway is an 11", so I would need the  "large" one?
Not sure which I would need.  Going to get a TCI Breakaway.
Also, I had bought new 5/16" bolts....the ones that need the 6-sided socket.....for the first install and re-used my crank bolts.
Do I have to buy all new bolts? Or can I re-use what i have safely if i locktite?
« Last Edit: October 08, 2009 - 11:57:58 AM by shadango »
Offline tactransman
« Reply #3 on: October 08, 2009 - 02:12:07 PM »
You need the small one for the Breakaway.
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #4 on: October 08, 2009 - 02:13:42 PM »
....also reuse the bolts and Loctite.
Terry-tactransman
Union, Mo.
Offline shadango
« Reply #5 on: October 08, 2009 - 02:25:44 PM »
Thanks Terry....you are a man of many answers!   :2thumbs:
Offline shadango
« Reply #6 on: October 08, 2009 - 02:28:05 PM »
Ok,,,,one more for Terry....
So the Breakaway is a 10" bolt pattern?  Is that what a stock converter is?
The Summit site says "3/8" bolt" in the description for the small bolt pattern one...
What are they referring to??
http://www.summitracing.com/parts/TCI-145600/
« Last Edit: October 08, 2009 - 02:30:32 PM by shadango »
Offline tactransman
« Reply #7 on: October 08, 2009 - 03:11:07 PM »
The Breakaway has 5/16 bolts (like stock) The 3/8 holes will work,but they will be a little bigger than normal.
This one will work,and it's cheaper.
http://chucker54.stores.yahoo.net/man10con.html
Terry-tactransman
Union, Mo.
Offline shadango
« Reply #8 on: October 08, 2009 - 05:15:03 PM »
Yeah, that is definately cheaper....half the price.....it looks exactly like the one I have...LOL
Nothing to be gained by gettng the TCI  then?
Offline tactransman
« Reply #9 on: October 08, 2009 - 05:17:17 PM »
Nope!  :grinno:
Terry-tactransman
Union, Mo.
Offline shadango
« Reply #10 on: October 08, 2009 - 05:22:28 PM »
Cool...Thanks!  Maybe I will see if Mancini's has a cooler too....save some shipping.
