Author Topic: Alternator questions  (Read 1138 times)
Offline vpittman
« on: October 08, 2009 - 08:58:52 PM »
I'm coming to the realization that it will probably be easier to replace the wiring (http://www.madelectrical.com/electricaltech/amp-gauges2.shtml) and buy a nw alternator than to figure out what is wrong with mine... anyway have some question about alternators...
This is for a '73 cuda with a 360 (not sure of the engine year)
1) All I'm really going to run extra is a radio/cd player (no a/c), is 60 amp enough or should I go 75 ?
2) I know this is subjective, but, any advantage to going with a one wire ?
3) Are the denso alternators (specifically http://chucker54.stores.yahoo.net/delialbrpk.html) one wire ?
4) Are desno pretty straight forward to install ?
5) If I don't go with the denso, what brand do you think is best ?
Also, regardless of which alternator I go with, is 10g wire good enough ? Or should I go with something bigger ?
Thanks !
« Last Edit: October 08, 2009 - 09:33:45 PM by vpittman »
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Alternator questions
« Reply #1 on: October 08, 2009 - 09:58:32 PM »
unless you are installing a big amp etc, a stock alternator will be fine.
Offline the_engineers
« Reply #2 on: October 08, 2009 - 11:39:42 PM »
Ted is right...60A should be fine.
If you want a Denso, read this...
http://goodysgotacuda.com/DensoUpgrade.html
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline vpittman
« Reply #3 on: October 09, 2009 - 12:36:27 PM »
Yea,
I saw that write up.. very good...
I guess the problem is, I don't know what I want
Thanks for all the input !
« Reply #4 on: October 09, 2009 - 05:47:12 PM »
the Denso is internaly regulated but you still have to connect 2 extra wires to make it work
